Deere L verses LA
Dave 39B
02-17-2008 16:08:40
He guys haven't been here in the Deere's before but I do have a few.Here's the question.What's the difference between an L and an LA.I have an LA which has crank and elec start,but I saw one that was listed as an L on ebay and it also had both.I thought the L was crank only.Just wondering and thanks fer any info.
Dave
Marv Scheb
02-22-2008 21:18:30
 Re: Deere L verses LA in reply to Dave 39B, 02-17-2008 16:08:40
On the Flange of the transmission cover where it bolts to the differential case there is a stamp. It will be either "L" or "LA" its usually hard to find because of paint and rust etc. and it is usually on top almost but sometimes its down the side a little. Have to look for it carefully. All La's had either solid 3 inch rod frames or very heavy wall 3 inch tube rod frame.
TSinMD
02-17-2008 20:09:46
Just an FYI. All LA's didn't have solid tube frames. I have seen many with hollow tube thick wall frames. I have heard many people say this is an easy way to tell the difference between an L and LA. I found out different when I first got into the hobby. One other interesting thing about hollow tube LA's is that you can't even say one is an early or later model as I know someone that has a 1945 that has been in their family since new!
Dave 39B
02-17-2008 17:00:00
Thanks Jim I just wasn't sure and It's always nice to be sure.
Dave
n29we
02-17-2008 16:42:29
Dave - All the L's and LA's had crank start but the later model John Deere powered L's had the option of electric start. I think the electric start was standard on the LA's along with a more powerful engine, solid tube frame and upgraded larger rear wheels and tires. JimO
