3020 hyd again
Larry M
02-16-2008 18:03:57
I'm still having trouble with the hyd on 3020. As stated before we replaced the brakes and now the center pump is not pumping to the front pump. Did open the line under left batt box and no pressure on it. You can hear a small whinng nosie coming from the center pump but no pressure. Just acts like it has lost its prime if that is possible?? Need help
Larry M
02-17-2008 02:27:58
 Re: 3020 hyd again in reply to Larry M, 02-16-2008 18:03:57
Thanks for the replies. New filter, syn range shift. Cleaned screen. Oil level is a tab bit over full, maybe a gallon. Valve body below left hand battery was replaced due to stuck pistons. Could this be the trouble maker?? Pump worked before the brake job. I can hold my ear down to the side of tranny and hear the pump running(I think that is the noise ,very faint) Any ideas????? ??
D.D.
02-16-2008 23:50:34
Not sure on the 3020"s but I have a 4320 that had the same type of problem. The suction pipe on these pumps fit rather loosely into the boby of the pump with and O ring seal, over the course of time the O ring wore out and it bagan to suck air around the tube. I replaced the o ring and it works good now. A small repair but a big job to get at it. Hope this helps
MSD
02-16-2008 21:58:52
When you bled the brakes did you take the screw all the way out or just loosen it? If you took it all the way out you may have lost the ball that is in there.
Mike w J
02-16-2008 19:49:22
Is this a powershift tractor and how long have you had it?
msb
02-16-2008 19:32:36
No, its not possible for the pump to lose its prime unless something is wrong with the pump itself.Lets review; Oil level is full? You did replace the hydraulic filter(2 filters if a powershift) and clean the suction screen? Correct ? I am curious as to how you can hear the pump whine ? Have you tried cracking the filter cap a bit? I have seen the pump gasket blow. You must remove the rockshaft to get to the pump. If your answewr is yes to all the questions then I would pull the rockshaft and have a look.
