plow for B
Jon Hurley
02-16-2008 15:21:25
I have a 41 B and will be looking for a plow in the future. Will it pull 2 bottoms if they were 12's? Thanks.
DickD
02-17-2008 13:59:43
 Re: plow for B in reply to Jon Hurley, 02-16-2008 15:21:25
Jon; It depends a lot on how deep you plow, and what kind of dirt you have. We pulled a 2-14 Oliver radex plow, which was noted for being easy to pull, behind a 39 B, and many times I had to shift to low gear, or crank it out of the ground some to get through that old black gumbo dirt.
old popper
02-17-2008 12:52:24
We always pulled 2/14's with our '42 B and believe it or not, in about three rounds would lap our '40 A with 2/16's. Always liked that plowing, the fresh turned earth, and working the tractor to the max.
JD 1956 60
02-16-2008 19:57:58
We pulled 2-14s with our 41 B. South central MN. Heavy black soil.
long green line man
02-16-2008 17:43:08
How about a JD #51 one bottom, 16" or 18"
RayP(MI)
02-16-2008 15:27:40
Should pull two 12" nicely in most conditions. May want wheel weights, loaded tires, or both.
