620 clutch engaugement
ET
02-16-2008 14:28:05
I looked at my friends clutch last night that won't snap in with the handle. We have put a working clutch and fork off another 620 tractor on Kevin's tractor and it still does not work. I pulled the fork back out and found that I can lock and unlock the clutch with a couple of pry bars. It seems like when the operating collar is pushed out to lock up, it needs to go farther than the fork can move it. Since the pulley locks to the drive disk it seems that drive disk is too far out on the crankshaft to allow the working range of the operating collar and clutch fork to line up. The depth from the end of the crankshaft to the drive disk doesn't seem excesive or to little. He did say that he has an aftermarket drive disk on the tractor. I have ran into some aftermaket parts with questionable machining on them. All the thrust washers on the crankshaft are in place and the end play is right around .005. With the pto drive gear in place and the snap ring on, not much can go wrong there. We have tried moving the operating fork one spline but that isn't the answer either. We are fast running out of ideas. I think the problem will be fairly simple when we finaly see it. This tractor came in a basket, a whole bunch of baskets actully.
Paul_IN
02-16-2008 15:32:19
 Re: 620 clutch engaugement in reply to ET, 02-16-2008 14:28:05
I had something similiar on a '52 B I rebuilt. The clutch just wouldn't snap in with a nice solid 'thunk'. I had a '51 B that did snap in really nice. So I traded parts. The problem stayed with the '52 tractor. I eventually found that my clutch collar was hitting a couple bolt bosses in the redution gear cover. I had to do a little custom grinding to get clearance. Then the original parts to the '52 were put back and all worked well.
ET
02-16-2008 16:11:33
 Re: 620 clutch engaugement in reply to Paul_IN, 02-16-2008 15:32:19
I tryied putting a layer of grease on the operating fork but couldn't see where it was hitting. I may do some more exploring along those lines.
