Big G, I set the float so the fuel level is about 1/8" below the gasket separating the upper and lower parts of the carb. As to setting the float to get this fuel level, it depends on the quality of your float. If the cork looks "good", I dry them out at about 130 deg in a small oven for a few hours, then coat them by brushing on two LIGHT coats (letting them dry in between coats)with a gas tank sealer that gets hard (some remain tacky so the float can stick to the bottom of the fuel bowl). I get mine at the local Harley Davidson dealer - it's white and is supposed to be alcohol resistant for the new fuels. This sounds like what you have done.A good starting point for setting the float is to have the float arm ~level (parallel with the fuel bowl). Then replace the bowl drain with a 1/8" npt hose barb, push a piece of transparent tubing over the barb, and wire the tubing so the top is above the gasket noted earlier. Turn the fuel on and see where the level settles to. Then take it apart and adjust the float arm to get the level where you want it. The point was made in another post about the importance of proper gaskets to prevent internal leaking. Deere sold the three critical gaskets C1141 (fuel bowl cover), C1142 (fuel control unit, bottom), and C1143 (fuel control unit, top) ONLY as a set, as they must be of the proper thickness so the three pieces seal properly as the carburetor is assembled. Several folks sell the gaskets, www.robertscarbrepair.com has them on line and they are good, matched gaskets. If you want to replace your cork float, brass floats are available, as noted earlier, but the float arm must be modified (actually, replaced). The website mentioned earlier also sells the float and arm, or you can buy the float and make your own arm.
