2840 JD Transmission Oil Pump
SHORTORDER
02-16-2008 08:09:55
The transmission oil pump on my JD 2840 tractor quit working without warning and I lost all hydraulic power. I separated the tractor and found the two oil pump gears completely tooth less. I know the two oil pump drive gears must be replaced. How do I determine if the transmission oil pump housing or the transmission oil pump cover needs to be replaced? If either one needs to be replaced, would getting them from a tractor salvage yard be acceptable? My gut feeling is no, but would like a second opinion. Does anyone know of a place these parts might be available after market. Thanks for your time and effort in solving this problem.
shortorder
ben brown
02-17-2008 18:27:09
 Re: 2840 JD Transmission Oil Pump in reply to SHORTORDER, 02-16-2008 08:09:55
if has some scars in it then it probley the orginal one as you know that pump pervides all the lube oil for the two speed and pto plus main hy pump. if you have any doughts go with a new pump. be sure and check and make sure the oil in take line is in good shape has no holes and a new suction screen making sure there no junk in the line so as not to damage the new pump.i think the gears might be avalibe through a& i. it also depends if you have the two speed in your tractor.
ben brown
02-16-2008 16:29:31
i would say the housing would be ok less it has some bad scars or schaches in it you might get the new gears then see if they fit good if not then by the housing. if it were me on that pump i go with new deere not sure you can get after market
SHORTORDER
02-17-2008 06:38:17
 Re: 2840 JD Transmission Oil Pump in reply to ben brown, 02-16-2008 16:29:31
Ben I really do not know how to ask this question but I will give it a try. The surface where the gears slide on or trun on as slight groves. You can catch on them with your finger nails. I would say there not more then a thousandths deep. The side where the gear teeth face is smooth but at the top there is a slight lip. I think that lip is showing wear. I have a tech manual but it does not give any measurements to check it by. If you got the time I would appreciate another comment. Thanks
