Antifreeze in 1951 All Fuel
Nathan Kapp
02-15-2008 17:23:04
Hello All, I was reading a post about the radiator freezing on the A and it got me thinking, on my 1951 B, I put antifreeze in and added water. So, will it mix? The way I did it was I added 1 gallon of antifreeze, then a gallon of water, then a gallon of antifreeze, etc. So, really, I did mix it. Do ya'll think its mixed well enough that I don't have to worry about freezing?
Thanks.
Nate
Nathan Kapp
02-17-2008 07:46:38
 Re: Antifreeze in 1951 All Fuel in reply to Nathan Kapp, 02-15-2008 17:23:04
Jd b puller, Easy there! I see your point and if I were anywhere near home and the tractor, you bet I'd be out there doing just that - but midterms in vet school have taken priority. What I was trying to do here is put my mind at ease and just see, if infact, water and anifreeze will mix on there own in an engine w/o a water pump. But you're right, it would be less time to change it than talk about it...haha. Thanks.
Nate
jd b puller
02-16-2008 21:35:49
 Re: Antifreeze in 1951 All Fuel in reply to Bobl1958, 02-15-2008 17:23:04
Nathan Kapp said: (quoted from post at 18:36:26 02/16/08) So looking at the results of Greg's experiment, we can safely assume that if you add coolant to the tractor using the 1 gallon of antifreeze followed by 1 gallon of water,etc until the tractor is full then run it to operating temperature, a homogenous mixture will result. I feel comfortable adding coolant to my tractor this way. What do ya'll think?
Nate
Nathan, are you so determined to prove these guys wrong that you'll risk breaking something? Dump the stuff out into a bucket, stir it up, and pour it back in. You've pi$$ed away more time talking about it than it would have taken to just do it.
CLW
02-16-2008 15:05:47
 Re: Antifreeze in 1951 All Fuel in reply to johns48jdb, 02-15-2008 17:23:04
You can do that but why not mix a 50/50 mix in a container and pour it in. That way you are sure it is mixed. Then store the remaining amount and if you need to top it off at a later time all you need to do is pour more in.
Nathan Kapp
02-16-2008 14:36:26
Nate
PBrowning
02-16-2008 16:21:59
 Re: Antifreeze in 1951 All Fuel in reply to Nathan Kapp, 02-16-2008 14:36:26
Nathan - I cannot go along with that. Far too many folks have been caught up with this problem, and while one person was blessed to not have a problem, a population of one is not large enough to bet the tractor on! But then -- as they say, "It's your tractor!" Fare ye Well. (PatB)
Nathan Kapp
02-16-2008 07:13:38
First, thanks Greg for those interesting pictures. Im interested to find out the results of sitting overnight! PBrowning, thanks for the info from the H restoration guide, when I get home next, I will be draining, mixing, and putting the anitfreeze back in the tractor. With that being said, I do feel that the coolant is mixed enough to prevent any damage to the tractor. I have the tractor stored inside our barn - there is no heat, but its a little warmer in there than outside. Plus, the temps here in PA havn't been too cold. Any more discussion is welcomed on this topic. Thanks.
Nate
CLW
02-15-2008 20:36:31
 Re: Antifreeze in 1951 All Fuel in reply to JHILL52, 02-15-2008 17:23:04
Nate, not necessarily. Your test may have been in a good part of the mix. Drain it into a 5 gal. can and mix it good. Then pour it back in. Don't take long to be safe. If it is to cold to be outside very long then just drain it in a can and refill it when you get better weather.
Nathan Kapp
02-15-2008 19:51:00
Okay, So I didn't mention that I changed the antifreeze in late July and did run the tractor up to operating temps 5-6 times since then. I did check the antifreeze with a tester and it tested well below 0 degrees. Wouldn't the antifreeze:water mix during general use? Im new to these old 2 cylinders, so any advice would be appreciated. Thanks again for all your info!!!
Nate
Skyhawk Greg
02-15-2008 21:50:22
 Re: Antifreeze in 1951 All Fuel in reply to Nathan Kapp, 02-15-2008 19:51:00
third party image
Here is a syringe that was first filled with about 2-1/2 cc of tap water. The syringe was then immersed into a cup of Prestone Antifreeze/Coolant, and 2-1/2 cc of coolant were drawn into the syringe. The photo is a bit out of focus (What happened to that macro capability?), but you can see that the antifreeze did not immediately mix with the water.
Skyhawk Greg
02-15-2008 21:52:09
 Re: Antifreeze in 1951 All Fuel in reply to Skyhawk Greg, 02-15-2008 21:50:22
third party image
Here is the same syringe, as it was slowly rotated 90 degrees from the horizontal. The picture is still quite fuzzy, but it can be seen that the fluids still are not mixing.
Skyhawk Greg
02-15-2008 21:57:24
 Re: Antifreeze in 1951 All Fuel in reply to Skyhawk Greg, 02-15-2008 21:52:09
third party image
The syringe is now rotated 180 degrees from the initial position. The reason for doing this, was twofold. First, to introduce at least a nominal amount of disturbance to the fluids, and secondly, to allow the syringe to sit overnight without leaking out of the hole where the needle should be. This photo was taken about an hour after the initial filling of the syringe (Notice that I am figuring out how to use the macro feature of the camera!). Tomorrow, I will post another picture showing the results after sitting overnight at ambient temperature.
Skyhawk Greg
02-15-2008 22:08:26
 Re: Antifreeze in 1951 All Fuel in reply to Skyhawk Greg, 02-15-2008 21:57:24
Nathan,
While waiting to see what happens in the next photo of the antifreeze with the water, I should add that I have never had a problem with completely draining a tractor, and then adding one gallon of antifreeze, one gallon of water, one gallon of antifreeze, one gallon of water, and so on, until my tractors were full. I will then run them until I see that the thermosyphon system is working, and that there is movement in the head tank of the radiator. This has worked just fine on two D's and a B, none of which has a water pump. If all of the antifreeze had been added first, and then the water, the results may have been different.
Greg
Skyhawk Greg
02-16-2008 07:43:05
 Re: Antifreeze in 1951 All Fuel in reply to Skyhawk Greg, 02-15-2008 22:08:26
third party image
This photo was taken almost 12 hours after the initial loading of the syringe. This syringe has been absolutely stationary since being filled with the water and antifreeze last night. Visually, the solution now appears to be well on its way to becoming a homogeneous mixture.
Skyhawk Greg
02-21-2008 09:31:58
 Re: Antifreeze in 1951 All Fuel in reply to Skyhawk Greg, 02-16-2008 07:43:05
third party image
Here is the same syringe almost a week later. The background is now a piece of white paper since this seemed to help show the uniformity of the solution. This syringe has not been moved in any way since putting it in this position.
PBrowning
02-16-2008 08:16:14
Greg - That was a very impressive demo that all Deere owners should be privy to. Thanks for sharing.
(PatB)
PBrowning
02-16-2008 08:16:11
(PatB)
PBrowning
02-15-2008 20:36:34
Nathan -- you didn't provide very much data in your post, so folks don't know where to start. But for all those reading this thread with you, the basis of discussion as realtes to premixing antifreeze with water is outlined below in a two paragraph excerpt from the JD-H Restoration Guide. I kind of think from your 2nd post, that your antifreeze solution is comingled okay. The test is the upper radiator tank. If it is getting hot along with the engine, you have circulation. (Pat) ----- ----- -----
COOLING SYSTEM -- The cooling system is built on the thermo-siphon principle wherein hot water rises over cooler water. As a result, the coolant circulates automatically without the need for a water pump�less parts to cause trouble. There is no thermostat to stick and no fan belt to slip. The coolant does not begin to circulate until the engine is hot enough to burn the fuel properly -- the circulation then keeps pace with the cooling requirements of the engine. Horizontal two-cylinder engine design has enabled John Deere engineers to place the engine on the same level as the lower part of the radiator so that the cool water enters the water jackets around the exhaust valves first -- the hottest part of any engine -- where cooling is needed most. A radiator curtain or shutter enables you to maintain this temperature under varying weather and work conditions. A water temperature gauge, located in plain sight from the tractor seat, tells you when to adjust the curtain or shutter.
ANTIFREEZE -- When adding antifreeze like the conventional green coolant such as NAPA brand prepared for NAPA by the makers of PEAK, strive to avoid having all of the antifreeze in the bottom of the cooling system. Don't just pour the antifreeze in first! Mix! Mixing antifreeze with water before pouring the mixture into the radiator will prevent development of an "antifreeze block" in your cooling system. In your JD "H" tractor, heated water will rise over unheated water because heated water has a lower "specific gravity," i.e., it is not as dense, thus lighter in weight. This "automatic circulation" does not happen until water in the lower part of the coolant jacket (engine) is heated to achieve this "less dense" state so as to rise. The specific gravity of "regular" antifreeze (such as PEAK) is 1.12. That is 12% heavier than pure water! Its density is not known to change much with temperature, and it will NEVER become less dense than pure water. So, if the lower half of your coolant jacket is filled with pure antifreeze, it just WILL NOT rise over water, meaning that you may have NO circulation! The temperature gauge reads HOT, yet the upper radiator tank is COLD. If this happens, drain, mix and then reinstall the mixture into the tractor. Caution: Never drain coolant from a super-heated engine; just shut it down and let it cool. ++++
Mike M
02-15-2008 18:30:12
Heads and blocks are getting scarce and valuable !
Drain it and mix it and test it then dump it back in.
jd b puller
02-15-2008 18:22:19
 Re: Antifreeze in 1951 All Fuel in reply to Mrbilman, 02-15-2008 17:23:04
According to previous posts on this (there have been a lot). -- No.
Drain it into a 5 gallon bucket and start over (with it mixed in the bucket).
johns48jdb
02-15-2008 18:04:20
i would have thought it would have been a good idea to run it for a few minutes at operating temperature. if your worried, mix a little of each in a glass and see what happens. i wouldn't set inside where it's warm though.
