Battery base and cushion on B???
Wayne_H
02-15-2008 14:28:49
Happy Friday: I started putting my battery box back on my 48 B today, and looking in the parts manual it shows 8 battery base cushions for the battery base. Mine certainly did not have that on it when I took it apart... Does anyone use these, or do you all bolt the battery base right to the seat? The part is B2562R.
Thanks a million
Wayne
Wayne
EdM
03-14-2008 19:12:53
 Re: Battery base and cushion on B??? in reply to Wayne_H, 02-15-2008 14:28:49
The correct price on these cushions is around six bucks. Still too high in my book. What I found out last month is that Deere made a lot of mistakes on their price increases. BUYER BEWARE!If it doesn't sound right, question them. My dealer did his job and contacted them and got them to correct the prices. How many dealers will do that....I don't know. I just cut up a piece of black automotive fuel line. Works great!
Pitalplace
02-20-2008 14:54:11
 Re: Battery base and cushion on B??? in reply to Mike M, 02-15-2008 14:28:49
Something that also works great is the cheap plastic marine battery boxes sold at Walmart for under $10. I use the base box to set down in the battery box but don't put the lid on it.
Dan-CA
02-18-2008 23:00:21
for rubber bumpers, try a truck supply house. Use the rubber grommets that are designed for the glad hands(air line hook-ups for trailer brakes)They are about 1 and 1/2 inch in diameter, 3/8in. hole in the center, and about 3/8 in. thick. also cheap
Wayne_H
02-15-2008 17:40:32
Thanks all. I'll call correct connection and see what they come up with. I did do the parts check on jdparts, and my stomach did a dance when I saw it was going to cost me a hundred bucks for 4 grometts.... Not even sure if they would be painted green....
Wayne
F-I-T
02-15-2008 16:33:49
Those are just a cushion type, large rubber grommet meant to support that false steel bottom off the very bottom of the battery box. They do help absorb some of the vibration that can get to the battery and shake it into an early death, but mostly when you are operating on really rough ground. A good substitute would be shock absorber donuts, or some stiff rubber hose cut into 1/4" or 3/8" slices, or get some 39 cent grommets at Home Depot. My check of JDPARTS shows them at around $17 each, so you might have found the record for a mis-priced part at Deere! Wow!
HTH
Frank
B-maniac
02-16-2008 17:08:59
 Re: Battery base and cushion on B??? in reply to F-I-T, 02-15-2008 16:33:49
Unless someone has an original to compare it to (which I doubt) then there's a good chance that even the ones that Deere has a pt.# for and a high price on are probably not any more accurate than what you could come up with if you shopped around. This has been proven out on a few items I have seen bought from them by a couple "Deere only" freinds of mine. Deere is riding the little"restoration train" too.
jdjerry
02-16-2008 02:29:23
Frank, Three or four years ago I was going to get the big nut for a G carb and the price from Deere was $107.00 . The part from Roberts or where ever I bought it was less than $10.00.
RobMD
02-15-2008 16:37:23
One note to make here, I took a piece of Rubber truck mudflap and cut it to basically fit in the bottom of the box. Then, I took a piece of rubbermaid tupperware that JUST fit in the box, and set the battery down in that. Now, if any sulfuric deposits build up and fall into the box, the tupperware catches it!
36 coupe
02-21-2008 15:51:45
 Re: Battery base and cushion on B??? in reply to RobMD, 02-15-2008 16:37:23
I put a piece of ply wood under my H battery.The steel plate was about gone from acid.
Rich Duane
02-15-2008 17:11:17
Correct conection in Rockwood,PA also has reproduction rubbers,bolts and proper nuts their number is 814-926-2777.
Rich
