Finding electrical problem
notanelectrician
02-15-2008 14:03:12
I would like to fix my cab light & radio & get them operational again. Sorry for the "dumb-question of the year", but how do I try to find out where my problem is? I have a test light, where do I start & how do I proceed? Any help is greatly appreciated & sorry for "wasting" your time.
Gerald J.
02-15-2008 17:08:15
 Re: Finding electrical problem in reply to notanelectrician, 02-15-2008 14:03:12
You have to trace the circuit from source, where you find power, to the loads where you don't find power. You can do it sequentially starting from either end. If you can identify many points on the circuit you can do a binary chop and find the fault quicker. With a binary chop, you check in the middle, identifying which half the circuit to test next. Then you check the middle of the remaining portion, until you find the problem.
Fuses, circuit breakers, and ground connections are more likely failures than wires, but a hungry mouse can have chewed through a wire.
Gerald J.
Wayne_H
02-15-2008 14:40:54
Hi: You need to find out if there is power to the light switch and radio. Do that with your test light, or better yet a volt meter. I suspect you have a fuse block in between the battery and the switches, could be a problem in the fuses???
If you have power to those switches, are the switches ok? does the radio work when it goes right to 12 volts? Is the light bulb good?
Good luck
Wayne
notanelectrician
02-15-2008 14:29:22
Forgot to mention that the fan blower & wiper WORK.
Bob
02-15-2008 14:35:21
 ? in reply to notanelectrician, 02-15-2008 14:29:22
Naw, you STILL forgot to tell us what you're working with!!!
Bob
02-15-2008 14:18:26
What are we working on?
If happens to be a SoundGard body, start with the cab relay and the breakers. That would apply to some other cabs as well!
