Correct Deere colors
GRW
02-15-2008 07:01:47
I'm painting my 4010 with Sherwin Williams Western brand 4th Dimention enamel base coat clear coat. They have 3 colors, lawn and garden, heavy equip., and J D green. Which one is correct for a 4010? Which is the lighter green? Or, does anyone have the DuPont numbers we could cross reference. Thanks for the help.
johns48jdb
02-15-2008 18:15:14
 Re: Correct Deere colors in reply to GRW, 02-15-2008 07:01:47
putting the jd buff primer under the yellow really makes it look good.
F-I-T
02-15-2008 08:28:57
third party image
The Dupont number for green, going back to the Dulux days was 262. 262 is used as a root part number for any of the newer chemistries (AE/Urethane) as well. In PPG Acrylic Enamel, I used 46180. BTW, Yellow for DuPont is the 263 code. I'm using DuPont Ful-Thane urethane yellow on a project in progress, and it is quite a tough, slick, hard coating. I painted my 70D using the 46180.
HTH
Frank
CarlF
02-15-2008 08:21:50
i bought my paint directly from the john deere dealer. i got the primer and paint.
it goes on very nice and appears to be a decent paint.
i am happy with the outcome.
Texasmark
02-16-2008 11:18:06
 Re: Correct Deere colors in reply to CarlF, 02-15-2008 08:21:50
Having gone through the restoration process and having used after market paints, I find that for all the trouble and expense I went through, to not have a stellar, like factory paint job, was most depressing.
Next time it will be from the local JD dealer and it will be right and all my time and energies will have been well spent. After all, after the work and $$$$ are all said and done (fade into the distant past) your only memory is what you see when you look at your tapistry!
Mark
long green line man
02-15-2008 08:02:27
I'd go with JD green , I think JD lawn & garden is a lighter green.
