4430 Temperature guage seems to read hot
bobinIL
02-15-2008 05:26:40
Yesterday I picked up my (new to me) 4430. While driving it home in about 30 degree weather I noticed the tepreture guage reading at 1/2 or a little above. I am used to the temp guage on other tractors and trucks usually reading around 1/4. Is this normal for these tractors? Should I start looking for a possible problem? The radiator looks very clean on the outside. Perhaps I need a new thermostat or a radiator flush.
Texasmark
02-16-2008 11:35:47
 Re: 4430 Temperature guage seems to read hot in reply to bobinIL, 02-15-2008 05:26:40
Interesting thread. I have a 4230 that has just been completely restored; and I mean completely.....well, not completely cause it only had 3900 original "mowing the pasture" hours on it...belonged to a guy who bought property, cleared it and sold it. So mostly the cosmetics got a going over while the drive line was ok intact with new fluids and all.
Anyhew all the fluids were drained and the coolant was drained and flushed with new hoses belts and all that. The coolant fluid is pristeen chartreuce, clear as a bell. The fins of the hyd oil cooler, A/C condenser, and radiator are clean.
I seem to have two spots where the temp will linger (which tells me I have 2 thermostats) and then move on up when plowing hard with the AC running in hot weather. I plow in the B 1-2 synchromesh area (plow in 2, up implement, pop over to 1 for the turn, down implement and back to 2. Pulls good and fast and I like to run discs fast to get the soil to lay right.
Sooooo I get into a similar situation where the needle works it's way over to the redline.
Recently I bought a laser remote temp sensor and upon arriving back home after plowing, I measured the temps at the head, mid cylinders and oil pan.
Don't remember the exact numbers, but the head was around 165, mid section in the low 200's, like 230 and the oil pan (not really a pan, more like a rigid casting) was above 260.
Well this guy does have an in-the-block oil to water heat exchanger on the left side to cool the oil.
So I am still up in the air on this. I probably am tugging on it too much and should drop down to the A gears or go to a smaller plow which would probably stop the problem.....but I don't want to do that. So I plow for a couple of hours and when it gets to nudging red, I just come home, let it cool, get out a beverage of choice and kick back. Tomorrow is another day. Grin
HTH, comments appreciated.
Mark
Indiana Boy
02-15-2008 19:44:33
I've been running 30 and 40 series Deere for years. A little over straight up and down is where they all run. If it gets close to the checked white and red or the red, it's time to worry. If not, you're fine.
buickanddeere
02-15-2008 07:36:31
It's working correctly. Isn't the cooling system supposed to keep the engine at a minimum of 180F ? You are aware that a engine running cooler than 180F wastes fuel and suffers increased wear? Where does this idea come from that "if too hot is bad, then colder is better" ?
long green line man
02-15-2008 06:00:12
Look for a problem ! poor circulation, stuck thermostat, temp guages can warp and be inacurate. good luck.
