After market JD A starter
Wuehler 2090
02-14-2008 05:45:10
I have a 1944 JD model A and im looking for a starter with with a built in cylinoid. I was once told a starter of a international 4000 swather would work but they made several diffent starters and im not sure which one it is. If anyone can get me a part # for a starter I would appriciate it. Thanks for your response.
old popper
02-14-2008 14:51:14
 Re: After market JD A starter in reply to Wuehler 2090, 02-14-2008 05:45:10
I too wanted a gear reduction (solenoid type) starter for my "G". The starter that I looked for was for a diesel "Bobcat" skidloader. The numbers I had were - Wilson 1113281. When I took it to NAPA he came up with a different #. 91-01-4310. This is a 12 volt starter that matches the bolt pattern,throws correctly into the ring gear and turns the right direction. If your "A" has been converted to 12 volt I am pretty sure this starter will fit the same as it fit my "G". I had to pay the core of course because I didn't have an old starter that model to trade in. I'm thinking around $275 all together. Hope this helps you. Dale
Wuehler 2090
02-19-2008 19:39:21
 Re: After market JD A starter in reply to old popper, 02-14-2008 14:51:14
THANKS FOR THE #'S ILL LET YOU KNOW HOW IT TURNS OUT
Mike M
02-14-2008 06:22:52
Put a threaded post in the starter and use an external solenoid like on a Ford Truck. But you will still need to engage the drive first. Or just put a NEW regular post and push button switch like it had when new and it will last for years. Change the brushes and bushings too.
