3020 hyd
Larry M
02-14-2008 02:19:31
Took the brakes off and replaced on a 3020 deisel and the valve on the left hand side off to clean metal out. Now it will not pick up its prime for the pump. No hyd anywhere on it works. No steering , brakes, or lift. Can some body tell me how to fix the problem? Some place to drain air out ???
mattd
02-14-2008 18:05:01
 Re: 3020 hyd in reply to Larry M, 02-14-2008 02:19:31
an easy way to see if oil is getting to the main pump would be to take the the supply line fitting loose right underneath the clutch pedal. its the big line on left side going through frame rail. wrap a rag around it and start tractor and as soon as oil shoots out then shut off. its gonna make a huge mess but it works. the stroke control valve is on the main pump which is under fuel tank. plug for valve is on bottom of pump on the left side looking at it from behind. do you have a powershift or syncro. if syncro make sure you arent holding the clutch down.
Bob
02-14-2008 06:22:09
Have you cleaned the suction screen at the bottom of the main case and THOROUGHLY flushed the brake debris out of the transmission/differential area?
Also, the stroke conrol valve on the main pump may be jammed by metal filings.
Larry M
02-14-2008 16:38:22
 Re: 3020 hyd in reply to Bob, 02-14-2008 06:22:09
Thanks Bob. The final drives and the screen are clean. The valve you spoke of on the main pump can you describe the location better? I wonder if a valve is stuck open on the left hand side below the battery box? Any help anybody?
Bob
02-14-2008 21:38:54
 Re: 3020 hyd in reply to Larry M, 02-14-2008 16:38:22
The stroke control valve is in the lump of cast iron bolted to the front of the main pump with four bolts.
There's a fine screen in there as well. The exact design and arrangement of parts in there changed over the years.
The first thing to do, is as the other poster said, and make sure the transmission pump is pumping oil forwards to the oil cooler/front pump.
The oil essentially feeds by gravity from the cooler to the intake side of the front pump, so, if there's charge oil getting to the cooler, the high pressure pump should be pumping unless there's problems in the stroke control valve unit.
Larry M
02-16-2008 16:05:51
 Re: 3020 hyd in reply to Bob, 02-14-2008 21:38:54
Still need more help. There is no oil going to the front.Opened the large line and no pressure on it with tractor running. You can hear a slight whine coming from inside the belly which goes away when you put your foot on the clutch . Normal correct?? So is the gears stripped in the pump in the belly? Is the valve under the left battery messed up? In that valve there is a threaded screw with a cap that goes over it can anybody tell me the correct setting for it. Help !!
