1010 question
Helmuth Kroog
02-13-2008 19:06:07
Hello:
I have a gas 1010 industrial and am going to rebuild the engine. At 6000 ft elevation, the 115 cid engine is short on power. I have a 2010 crank to use but want to know if the 3-1/2" cylinder liners can be bored to 3-5/8" so I can use standard 2010 pistons? Will I have to use a 1010 diesel or 2010 gas deck plate assembly?
thanks for your knowledge? Helmuth
Helmuth Kroog
02-14-2008 18:59:14
 Re: 1010 question in reply to Helmuth Kroog, 02-13-2008 19:06:07
Hello:
This brings up another question. The Id plate is missing off the side of my 1010 engine block. I checked casting numbers on the transmission, clutch housing and a couple of other places. The numbers all indicate it was a late model. However, this does not provide a difinitive indication of the year. Is there a way to identify the serial number other than from the engine tag?
jdemaris
02-14-2008 08:02:00
1010 gasser loses 6.5 horsepower at 6000 feet.
That's why turbos used to be called "altitude compensators."
I know 1010 gassers were Nebraska Tested at 36 maximum horsepower - but I've never witnessed it. I worked for three Deere dealers over the years and had many 1010s on dynos. I've never seen one pass 32 horsepower and we are at 1600 feet elevation - which should put the 1010 at 34 horse here.
raddlechain
02-13-2008 22:29:25
Yes, just go with a good "2010" sleeve and deck plate,as you might run into some trouble boring the 1010 sleeves to 2010 specs. At sea level, the difference between the two engines is about 10 hp (36 vs 46), probably something less than than that at your altitude. Something you want to watch for if your 1010 is an early one prior to serial number 42001. The ring and pinion gears on the early tractors were a touch fragile, but you'll be OK as long as you don't use all the increased power in 1st or 2nd gear, or lug it hard for a long period of time. Tractors serial number 42001-up had stronger gears and should give no trouble.
buickanddeere
02-14-2008 10:30:23
 Re: 1010 question in reply to raddlechain, 02-13-2008 22:29:25
If memory serves the 1010 updated the r&p at the end of 430 production/start of the 1010's. Then strengthened again at 31,001. 42,0001 had the new high pressure hydraulics etc. The pre 31,000 1010 r&p will also physically bolt into a post 125,001 420/430/435/440 and beef up the two cylinder driveline.
long green line man
02-13-2008 20:27:48
1010 & 2010 gas use same block (marked T16277) so makeing the 115ci into 145ci should work . I would go with a good used 145ci sleeve plate instead of reboring, should be cheaper.
