1020 Diesel Starter wont work
Frank in WV
02-13-2008 11:44:03
I went to start my 1020 this afternoon, the starter made one small burp of movement then quit! I thought I saw a puff of smoke come up out of the battery area. Now when I turn the key to start the ammeter discharges slightly, the red electric light on the dash goes out but nothing happens, starter will not budge.
Do I need a new switch, it is original one with tractor? Tractor started fine last night but today was no go.
Frank in WV
02-13-2008 14:15:10
 Re: 1020 Diesel Starter wont work in reply to Frank in WV, 02-13-2008 11:44:03
Thanks to all, I cleaned the battery terminals and wa la it started. Sometimes the easiest fix is overlooked. I now was able to plow the snow out of the driveways. :)
johns48jdb
02-14-2008 06:30:08
 Re: 1020 Diesel Starter wont work in reply to Frank in WV, 02-13-2008 14:15:10
sorry about that. if i had known my answer was in any way going to put you to work out in the cold i wouldn't have answered. you northern guys can keep all the snow up there with you'll. we don't need it in n al.
johns48jdb
02-13-2008 14:12:25
hope you aren't standing out in the cold when you read this, but nothing electrical will ever work again if you let the smoke out. you may have to clean the cable connections twice to get them right. clean both ends of the cables. don't use cheap replacement ends for battery cables. use those for tractor trailer rigs. real heavy duty ones. in the summer time in high humidity areas i've had to clean them twice a day. if they are black then they need cleaning bad. be careful not to remove to much of the post because the cable want tighten down on them good. i prefer the cleaners with the wire brushes in them to clean cables.
Rancher
02-13-2008 12:19:38
Sounds like you need to clean up your cables.If not that your starter may need replaced.Good luck that kind of thing can be fun!
Gerald J.
02-13-2008 12:09:37
Get thee a battery post brush and clean and tighten the battery connections first.
Gerald J.
Hoss in Maine
02-13-2008 11:59:32
Sounds like a poor cable connection. Later Hoss
