JD 4250 clutch adjustment?
JDBrian
02-13-2008 07:40:49
What does it take to adjust the clutch on a JD 4250 powershift(or is this even possible)? Looking at a tractor and was told the clutch needed adjustment. Can it be adjusted or does the transmission need rebuilt?
Kevin Schmidt
02-13-2008 14:38:32
 Re: JD 4250 clutch adjustment? in reply to JDBrian, 02-13-2008 07:40:49
There is no engine disconnect clutch on a 50 series tractor. Could be in the valve the clutch pedal is hooked to. If the tranny is soft, could be just a tranny pump (still $$$$) or the tranny is shot. If you can tell some gears are better than others, it can be in a certain clutch pack. It could be a lot of things, most are expensive, but it isn't an adjustment.
Gerald J.
02-13-2008 09:01:03
There probably is ONE mechanical clutch, the engine disconneect that is hardly ever slipped so it should not be worn or needing adjustment. In what I know of 4020 PS transmission, everything else including the "clutch pedal" (actually properly called the inching pedal) is hydraulic so there's nothing to adjust. But those clutches do wear and hydraulic pressure drops off from plugged filters and worn out pumps. Not reacting well to the inching pedal probably means lots of repairs needed unless its simply a dirt filter or low oil.
The wrong oil wrecks clutches and wet brakes too.
Could be expensive, could be cheap. caveat emptor.
Gerald J.
