1951 JOHN DEERE A
Daniel Trainer
02-13-2008 06:05:45
hope someone can answer my quistion, my radiator on my A keeps freezeing at the neck and i keep putting antifreeze and i just keeps doing it, im afraid that its going to bust my radiator or even my block, hope someone can tellme what wrong,
Ravgardner
02-13-2008 08:59:57
 Re: 1951 JOHN DEERE A in reply to Daniel Trainer, 02-13-2008 06:05:45
Absolutely right. Your A, does it have a water pump? If not, the water and antifreeze will not mix inside the engine, it must be mixed before it is poured down the spout.
Daniel Trainer
02-13-2008 13:03:16
 Re: 1951 JOHN DEERE A in reply to Ravgardner, 02-13-2008 08:59:57
sure dont have a water pump, igot it stated and let it run at idle it heated up the ice and melted it, hope i didnt mess anything up
RobMD
02-13-2008 14:22:39
 Re: 1951 JOHN DEERE A in reply to Daniel Trainer, 02-13-2008 13:03:16
Daniel,
If you read mark's statement below, he's dead on. The reason why you need to drain this out is because tractors without water pumps do not mix antifreeze on their own. You need to mix a 50 50 mix thoroughly before putting it in, or else it will be separate the whole time.
This can also cause overheating.
Mark-Ia
02-13-2008 06:23:20
Drain all the coolant out of your cooling system and make sure it is throughly mixed BEFORE it is poured back into the radiator. 50/50 mix of water and antifreeze will keep it from freezing.
