All Fuel Tractors:
Momsworry
02-12-2008 17:02:01
I realize they were designed to run on distillate and kerosene. What about diesel fuel, would they run on that too? Just curious.
jd40an
02-13-2008 07:52:41
 Re: All Fuel Tractors: in reply to Momsworry, 02-12-2008 17:02:01
I started farming with an "All fuel G", just as it came from the factory. I used #1 fuel oil(the same as #1 diesel & I know because I also drove a fuel truck part time). The "G" ran well on the #1, by the time I got to the field, running on gasoline, & before the small tank ran out,just switched over & went ahead with my field work. There was, however, enough oil dilution that I usually changed at about 50 hours.
Ben.So.Tex
02-13-2008 04:40:05
Many years ago I ran my 45 B on diesel and it did fine. I tought this was wierd since running it on diesel the tractor quit burning oil. "BUT" when I went to change the oil about 5 gals of oil came out of the crankcase. Alot of diesel was slipping by the rings and mixing with the oil. I never put diesel in it again. Good luck Ben
RobMD
02-12-2008 19:10:20
you would be fine for about 5 minutes and then you'd have to change the plugs. Trust me, i've been there, done that. Start it on gas, warm it up, and switch over to kerosene.
Mike M
02-12-2008 18:39:01
Every tractor will act different on it. I ran my model H with #2 and it ran fine. Tried it in the model A and not so good. The A ran fine on K1 switched it halfway down the field plowing and couldn't tell a difference other than smell.
raddlechain
02-12-2008 17:48:12
I think F-I-T is right---you might get one to run on No.1 diesel, but it would have to be on the ragged edge of boiling, with water temps to be at least 210 degrees--difficult to regulate between 210 and boiling. Deere built a few Model "D" tractors with special "hot" manifolds for burning really heavy fuels, but those manifolds are few and far between. Don't have the part number handy, but with those manifolds, the exhaust and the muffler were on the same side of the tractor as the intake. Supposedly, these would burn No.2 diesel and even heavier fuels, but little is known of them. Most were installed on tractors destined for export.
old
02-12-2008 17:14:49
Back when diesel cost a lot less then gas we would run our 1935 JD-B on a mix of 50/50 gas/diesel and it seemed to have more power then just straight gas. Also at idle it would puff out big smoke rings
F-I-T
02-12-2008 17:11:20
Any that I have seen try to run on #2 Diesel fuel foul the plugs in short order. . Less but about the same problem when you go to #1D. You have to have them awfully hot to even get close to a chance. Even on Kerosene, they have to be warmed up right and working hard to do well. I can make one run pretty nice while it is on the dyno running fully loaded, but the moment you remove the load and they begin to cool down, they'll start to spit a bit. The kerosene aroma is quite different than you are accustomed to when they are running under a nice load.
JMHO
Frank
almrm
02-13-2008 10:58:19
 Re: All Fuel Tractors: in reply to F-I-T, 02-12-2008 17:11:20
Frank,
I thought of trying diesel in my 35 A under load. After your comments I think I will pass. Isn't there a build up problem if you switch from diesel to gas in the same tank. I have no data but seem to recall that it was a practice to change gas tanks in autos or trucks if you change from diesel engine to gas. The early 350 diesel GM engines often failed early and were replaced with gassers and I believe a new tank was in order. I have one red plastic gas can that I have had both diesel and gas in and it has a dark coating on the inside walls. It is now used for drain oil. Is there anything to this?
Mark
F-I-T
02-13-2008 12:53:42
 Re: All Fuel Tractors: in reply to almrm, 02-13-2008 10:58:19
Mark:
I'm not sure that there would be a significant cross-contamination factor, by having a vestige of "other" fuel in the tank, especially in a something so wildly jetted as an "A". The residue, which is some heavy tar component, would probably dissolve with a lighter fuel like gasoline, but if you are concerned, swish it with a triple rinse of MEK and that should reduce the ppm's way down. The switching of the diesel tanks upon conversion might have had to with how they were vented, since a different in-tank fuel pump was more than likely called for. Can't say for certain.
