problem with my 345 tractor
Armand L Lancia
02-12-2008 09:23:48
MY tractor with cab and chains has developed a side to side rocking. If I drive slow the rocking is slow, if I inccrease speed tthe rocking really gets bad. I talked to my dealer and his response was "I've never heard of it". It is snowing right now and I have a very long drive way {uphill} that needs to be cleaned,However I am afraid to use the tractor. iy really rocks side to side Can you please help me?
sds46a
02-13-2008 01:10:53
 Re: problem with my 345 tractor in reply to Armand L Lanciault, 02-12-2008 09:23:48
Have someone take the chains off and try it. I'm betting on the chains.
Doug
jd b puller
02-12-2008 18:49:20
 Re: problem with my 345 tractor in reply to Kent Petersen, 02-12-2008 09:23:48
Armand L Lanciault said: (quoted from post at 14:38:11 02/12/08) My 345 was bought used. I bought a cab and I use chains. Back in Dec. It developed a violent side to side rocking,I talked to the deler and his answer was"I've never heard of that". I have a very long driveway [uphill] that needsto be cleaned [5inches oof snow]but I'm afraid to use the tractor because the faster I go the more it rocks Can you please help me.I'm 84 and can't shovel that much snow.
Armand, I haven't seen this either. If you are off the tractor and just try to push it side to side, does it seem to have slop in it. If memory serves, there's 4 or 5 bolts that hold the wheel on to the hub, but ultimately, the hub is just keyed to the axle. Might be that it's sloppy in there, or maybe the bolts are loose. Hub may have rubbed into the housing, esp if it's used on heavy loads or hillsides a lot. Would need your Serial number to know which style washer you have in there.
RobMD
02-12-2008 15:49:27
Rocking side to side sounds like the chains. The gaps between your cross chains can cause that rocking side to side. Chains normally cause rougher riding tractors, especially on lawnmowers.
Maark
02-12-2008 11:28:30
Does it have fluid in the rear tires that has frozen and throwing your tractor off balance as the wheel turns????
Armand L Lanciault
02-12-2008 09:58:13
All I know is that it is a 345 twin automatic transmisson,water cooled, hydawlic lift,with cruise controll, lights,snow blade, mower.
Armand L Lanciault
02-12-2008 10:38:11
 Re: problem with my 345 tractor in reply to Armand L Lanciault, 02-12-2008 09:58:13
Armand L Lanciault
02-12-2008 10:29:59
Armand L Lanciault
02-12-2008 09:57:38
Armand L Lanciault
02-12-2008 09:34:00
Armand L Lanciault
02-12-2008 09:33:56
