420 water pump question
L.C.
02-11-2008 21:49:24
My current project is a '58 420T. I discovered that the water pump has almost seized. I was told by the local Deere dealership that the shaft and bearing assembly (JD 8549T) is no longer available and that there was not a replacement/sub part number. All of the other basic rebuild parts are still available with new part numbers, but not the shaft and bearing assembly. Do y'all know of a newer part number than the JD 8549T for the shaft and bearing (may be able to sub from that number), or, do you know of another source for the shaft and bearing assemblies?
L.C.
02-12-2008 15:41:33
 Re: 420 water pump question in reply to L.C., 02-11-2008 21:49:24
Thanks, y'all. I thought about going with a new water pump (you can order them right here at YTmag), but I wanted to look at rebuilding the old one first.
Dave H
02-12-2008 15:06:33
I was reluctant to chime in, but Mike broke the ice. i overhauled my 58 420 water pump a while back and got the parts from the local in the know JD Dealer.
I always thank them because the money they make off me sometimes don't add up to the free pop corn they have.
JD40203020620420
02-12-2008 07:52:49
A&I makes new water pumps for the 420 also. Just a couple bucks more than you will have in the parts for a rebuild.
CPeter
02-12-2008 07:22:45
CHinNY is good too.
CPeter
CHinNY
02-12-2008 06:54:14
Email me for my web site i stock new waterpumps
Mike M
02-12-2008 06:44:14
What is it with these Deere dealers ?
Drop the T off the end and it now subs to JD9377 for $25.75 and my dealer even stocks one.
L.C.
02-12-2008 15:37:28
 Re: 420 water pump question in reply to Mike M, 02-12-2008 06:44:14
This guy's young, but he's trying, which I appreciate. I'm still learning, too.
Thanks for the #. Looks like I need to start learning about the parts website.
