4010 heater
123 farmer
02-11-2008 17:18:08
I recently bought and installed a canister heater on my 1961 4010 to use as a block heater. I bought the hearter from tsc. For the water going into the inlet i ran hose from drain on left side of block and went in fron of block to other side where i mounted the heater by the oil cooler. abd then i ran the outlet hose to the plug that is on the head just above the water pump. when i plug heater in it heats really good only problem is hot water is traveling through the copeer line that goes from the water pump to the water maifold where thermistats are. Is this ok and is water still going back to the block and head or should i put the outlet hose in the plug in the rear of the head where the temp. gauge is currewntly and move temp guage to front plug. i have no pugs to water jackets in the side of head. thanks
LarrySTN
02-11-2008 19:25:35
 Re: 4010 heater in reply to 123 farmer, 02-11-2008 17:18:08
Are there no plugs in the right side of the head between the injectors?
123 farmer
02-11-2008 19:36:13
 Re: 4010 heater in reply to LarrySTN, 02-11-2008 19:25:35
no there are no holes there only holes are the one in front and one where temp guage is.
LarrySTN
02-12-2008 04:23:28
 Re: 4010 heater in reply to 123 farmer, 02-11-2008 19:36:13
Your 4010 must be unusual. Every 4010 that I have seen has recessed plugs in the head, between the injectors. The plugs are 1/2" pipe thread and have an internal six side drive. They can be very hard to remove, but heating the plug with a torch usually helps.
