JD 300 tractor loader backhoe
Ivan Pavlovich
02-10-2000 10:11:27
I have an industrial JD 300 TLB with a 3 cyl. gas engine. It has a bunch of blow by and I'd like to rebuild it. Can anyone tell me what JD farm tractor used the same engine? Also, what years these units were made, hp, etc. It has the hi-low range with reverser setup. Also, Would it be possible to put a 3pt hitch on this unit and a pto? Thank you for your time. Ivan
ROBERT
02-11-2000 22:01:44
 Re: JD 300 tractor loader backhoe in reply to Ivan Pavlovich, 02-10-2000 10:11:27
allso your ag dearer has eng kit book for your IND tractor.no need to gess ROBERT
GENE
06-20-2001 19:23:11
 Re: Re: JD 300 tractor loader backhoe in reply to ROBERT, 02-11-2000 22:01:44
INFO TO REPAIR OR FIX BACKHOE CONTROL VALVES
Dave Wickman
02-10-2000 13:23:17
Ivan, Any of the Dubuque three cylinder Gas or Diesel engines will fit in your tractor. I am not sure what size engine is in your tractor. I think it is 164 or maybe 152 cubic inch engine. The farm tractors that used three cylinder engines were 820's, 1020's, 1520's, 1530's, 2040's and later 2240's. Cubic inch size engines available are 152, 164, and 179. I think the 300 was more like a 1020 than any of the rest but all are very simmilar. Yes a PTO and Three point could be taken off any of the mention models and put on your 300. Don't know if the Backhoe will inerfere with this or not?? But will fit the tractor with the hoe removed. Good Luck!! Dave
john
02-10-2000 16:38:55
 Re: Re: JD 300 tractor loader backhoe in reply to Dave Wickman, 02-10-2000 13:23:17
Its a pice of junk .
