best way to get tires on
joelrand
02-11-2008 10:38:24
After painting the rims and hubs, once the new tires are mounted, what is the easiest way to get the rim/tire back on the hub and tighten the clamps? On the axle, so you have to hold the tire vertically and line it up with the hub or on the floor and then lift the tire/rim/hub all as a unit? I'll likely be by myself or the wife may try to help.
johns48jdb
02-12-2008 05:09:23
 Re: best way to get tires on in reply to joelrand, 02-11-2008 10:38:24
the idea of a pry bar under the tire works, however if you have one that is shaped like a "y" then it works better. its more stable that way since your furnishing all the muscle and brains too. if you make such a bar fix where when the two legs are li=aying flat on the floor your handle is bent up slightley to allow you to get a grip on it. lay the bar down and roll the tire over on it and go from there. if your interested in a way to paint the rims, hubs and bolts without getting them messed up em me and i'll em you back some instructions on a neat way to do it. be careful. [email protected]
Texasmark
02-11-2008 19:39:02
I have mounted some pretty heavy tires alone. Thing is to keep them vertical and don"t let them tilt or they will get away from you.
I put the tire against the hub with about a 5 degree tilt toward the tractor so it doesn"t fall over.
Then raise or lower the jack as appropriate till the holes almost line up....want the hub holes/studs (whichever) slightly higher than the tire/wheel holes.
Rotate the hub so that you are aligned with the wheel and lock the hub with the brakes.
Then take a steel rod, wrecking bar or whatever you can find and put it under the tire, on the floor and put a 4x4 under it as close to to the tire as you can get so that you have leverage against the wood. Your leverage gain will be significant.
Have a nut or bolt as applicable ready and with one hand steadying the wheel, prise up on the bottom of the tire till one hole lines up. Get that one started. If it won"t line up just move the rod over toward the side you want to lift and you can rotate the tire/wheel that way till it lines up.
Then with the rod end on the floor with the 4x4, go to the edge of the tire and rotate it around till you can get a second hole-stud lined up, preferably across from the first and start that one.
You are good to go from there.
Mark
machinery-man
02-11-2008 16:46:26
Sounds like you might be flirting with a high risk of injury on your plans. I use a lift and can set the center on tractor axle. Bolt that in place then strap the tire/wheel combination and position it in place. Never tried a whole unit and it is very unstable. Better get a lift and some help.
joelrand
02-11-2008 16:27:19
these are 15.5 x 38 on double bevel rims for a 720D.
old
02-11-2008 10:44:33
It would help a lot to know what your working on since there are many different ones and types of axles and because of that theres different ways to do each type. I.E. Some have a screw type mount for adjusting the wheels some have U bolt clamps and some have other ways to mount them
