420 steering problem
ezed76527
02-11-2008 06:38:36
I have a 1957 420 wide front that has steering issues.
I have adjusted steering box, replaced flex joint and tightened connection between steering shaft and steering box. Still have wobble in front wheels. Tie rod ends are tight Is there another adjustment or possible wear area? I am thinking that there must be another gear/shaft in lower portion of steering box.
any suggestions?
Dave H
02-11-2008 16:35:15
 Re: 420 steering problem in reply to ezed76527, 02-11-2008 06:38:36
After you check it like Ray indicated, you will probably find the slop in the splied coupling under the 90 degree box or in the bottom bushing on the 90 degree box or on the splined part on the bottom of the vertical shaft that actuates the tie rods or a combination or all three.
good luck
Ray
02-11-2008 11:23:01
Jack the front end off the ground,with a jack under the center casting to get both wheels off the ground.Then shake the tires back and forth.
You should be able to see where the slop is.
rusty wheel
02-11-2008 09:55:58
Sounds like the lost motion might be in the spindles. I have a 40-w that has a little wobble in the right front wheel but none in the left wheel. Raise the front wheels, one at a time, and see if the wheel wobbles without the tie rod movng..... ..... ...rw
