2010 Transmission
sofaking262
02-11-2008 06:33:44
I'm wondering if anyone out there has ever been able to change a speed change shifter cam in the speed change compartment on a 2010 Syncro Range trans? The service manual has you splitting the tractor to do this,but when you take off trans cover it looks like it can be done from above without removing shifter fork from case.Any help would be appreciated,Thanks
Art C
02-17-2008 05:19:59
 Re: 2010 Transmission in reply to sofaking262, 02-11-2008 06:33:44
I have the transmission cover off my 2010 right now and you might get lucky and get the cam out without splitting the tractor. You have nothing to lose by trying it, just don't pry on anything or force it , breaking one of the internal peices might be very expensive or impossible to get. Also watch you don't lose the rollers on the end of the forks, they fall off the early models really easy. Move the cam downward until they are exposed and slide them off. Good luck.
sofaking262
02-17-2008 06:01:37
 Re: 2010 Transmission in reply to Art C, 02-17-2008 05:19:59
Thanks for your reply Art C.I was able to remove the cam from above and as you stated you have to be careful with the rollers.You also will want to have a third hand to help get the castle nut started.Once that"s done everything else goes pretty easily.Be sure to line markings on shaft and cam when installing.Again,Thanks for your reply Art C, Kim
