A real head scratcher!
farmboy169
02-10-2008 20:13:03
Good evening. I have a '46 D that I just got running this past fall after a complete tear down and rebuild(what a task!!!) During the break-in period when it got up to operating temp. (180-190) it would kind of lose power, spit and spuder, and sometimes die. It runs and starts perfect otherwise. The head was gone thru completely by a local machine shop with a lot of experience with 2 cylinders. I have adjusted the valves cold but not hot yet, could this be the problem? Thanks guys.
Mike M
02-11-2008 12:42:51
 Re: A real head scratcher! in reply to farmboy169, 02-10-2008 20:13:03
Have you tried opening up the fuel mixture adjustment ?
On the valve adjustments if it says .020" hot set them at .022" cold and you will be ok when hot. You have to make sure the rocker arm faces are not cupped so you can get a good reading.
DickD
02-11-2008 03:23:21
I had an A that acted the same way. It had a new set of resister plugs in it. I changed the plugs to non resister, and it ran fine.
Bob
02-10-2008 20:22:32
A bad coil or condensor will act like that as it heats up (as well as the things you are considering).
