Farbanks Mag installation Question
Bguy
02-10-2008 07:05:42
I am installing a FM RV2B mag on a 1935 B which has a WICO C on it now. Since the FM only fires every forth rev., how do you figure out the timing without using the trial and error method which could take a while. Can I turn the mag until it's time to fire, set the flywheel to the correct fire position and be close? Also, which tower is for #1 cylinder?
Thanks.
Duane Larson
02-10-2008 08:03:46
 Re: Farbanks Mag installation Question in reply to Bguy, 02-10-2008 07:05:42
Bguy,
Rotate flywheel until flywheel side piston is at top of compression stroke, and LH Impulse is then lined up with mark on transmission case and the magneto drive flange should be horizontal. Your magneto does the following: click(spark)-click(spark)-click(no spark)-click(no spark) and the pattern repeats. Hold your magneto in a vise like it will be mounted on the tractor, and run a plug wire from the bottom HV outlet to a plug laying on the vise. Rotate your magneto until you get a spark at the plug, and stop immediately after the spark occurs. The drive flange should be close to horizontal and mate up with the driving flange on the end of the governor shaft. Bolt the magneto in place, and run the bottom plug wire to the flywheel side plug and the top wire to the pulley side plug. Then I would adjust the running timing (by rotating the magneto within the slots) with a timing light. There is no adjustment for the impulse (or starting) timing on the DRV2B.
Bguy
02-10-2008 11:39:24
 Re: Farbanks Mag installation Question in reply to Duane Larson, 02-10-2008 08:03:46
Thanks Duane! I'll give that a try.
