JD 4020 drains on engine
Troy Pinkerton
02-09-2008 19:14:12
I have a '68 4020 and noticed a few small holes on the drivers left side of the tractor. Do these holes drain the piston? It looks to me like a little antifreeze is draining? Is this a major cost repair? It is a really good looking and running tractor. I realy have no trouble with it otherwise and need an experts opinion on whether to keep it for my farm or what? It may smoke only a little at startup but otherwise exhaust is pretty clean. All suggestions are appreciated. Thank you.
John in MD
02-10-2008 01:37:38
 Re: JD 4020 drains on engine in reply to Troy Pinkerton, 02-09-2008 19:14:12
This was a quick fix that I saw at a Pa. auction. The owner was putting golf tees in weep holes and trimming and spray painted repair. It stops the leak and doesn"t hurt anything. Just keep a close eye on oil for any signs of anti- freeze
Gerald J.
02-09-2008 20:19:14
Later vintage (side console) 4020 engines didn't have those weep holes. I think I've seen a JD service bulletin that suggests the weep holes could be intentionally plugged without damage. Probably they figured the bottom ring was less likely to leak than the one above it.
I think the thing to watch out for is for the weeping on a cylinder to stop. Then is the time when the bottom seal has quit and that antifreeze is going into the crankcase. Antifreeze and bearings mix only for a short time and then the bearings go bad.
Gerald J.
long green line man
02-09-2008 19:47:38
There called weep holes, means that anti freeze is getting pasted 1st. or 2nd. o-ring on sleeve, but not sealing ring on bottom, Keep checking for anti in bottom of crankcase (slowly thead out drain plug.) hope this helps.
LarrySTN
02-09-2008 19:41:47
The holes in the left side of your block are intended to let out coolant should the upper o-rings on the sleeves start to leak. If the engine does run fine I would put some stop leak in the cooling system to stop the leak. I would also have an oil test done every oil change to see if there is any coolant getting into to crankcase. As long as no coolant gets into the oil you will be fine. Test kits are available at your John Deere dealer.
Troy Pinkerton
02-09-2008 20:33:44
 Re: JD 4020 drains on engine in reply to LarrySTN, 02-09-2008 19:41:47
Thank you to all!
