Deere B
Sam from WA
02-09-2008 19:10:31
I got the old B to fire off today, but it refuses to run on its own for very long. It still surges pretty bad, but is NOT a carburetor problem. I put the carb on a friend's B to see what it did, and his tractor ran fine. I tried Pat's tests and it passed with flying colors. what I'm begining to think is we have more major problems somewhere. Might the cam be off by a tooth? I've been workin on the tractor with my dad, and we're both lost.
F-I-T
02-10-2008 19:49:19
 Re: Deere B in reply to Sam from WA, 02-09-2008 19:10:31
I would first try disconnecting the control rod from the governor to the carb at the carburetor end and see if you can run the engine by operating the carburetor butterfly without the governor attached. If you can hold it in one position and the engine runs true, then you probably have a governor that is somehow out of whack, a control rod too long/short, lost a governor weight, have a binding in the governor to carburetor linkage, etc. Also check for a mis-positioned cotter pin at the carburetor end of the rod. These can bind the linkage, then the engine starts to slow, then the governor relaxes so the throttle spring overrides the governor pressure and kicks the butterfly wide open, so it speeds up, then the governor presses to close the butterfly, and the vicious circle repeats.
You should be able to run any of these engines with your hand just like hand throttling a car or a lawn mower.
HTH
Frank
Lee B
02-10-2008 17:27:11
In the famous "one hole short" adjustment scenario of the carburetor/governor linkage try it with one half hole instead. Or even a straight drop in length (no hole short). I'm betting it's just a very sensitive governor adjustment slightly misadjusted.
My A did something similar when I overhauled the governor. I was not happy with the hyper critical adjustment tolerances and got around that by extending my governor arm about twice it's normal working length. So now my governor actually kicks in and works at just off idle while puttering around parking implements for example where it used to just die if I engaged the clutch like that.
johndeereman
02-10-2008 08:27:35
maybe u lost a gov. weight?
Dean Sunram
02-10-2008 06:22:12
Check out your governor to see if your thrust bearing is working right. If it was sitting around for awhile it could be sticking on the sleeve. Good Luck
Kris A NC
02-10-2008 06:06:28
What model of carb do you have on your '48? What year is the friends you tried it on. I had to put a DLTX34 (for '41 - 47 AllFuel tractors) on a '39 B one time to get me by. It would surge at idle cause the carb was not the correct model for that year...Just my experience. When I had the DLTX10 back on the '39 she ran great. Just my .02...my not even be worth that.
Kris A NC
johns48jdb
02-10-2008 04:55:40
remove the hose coming from the air filter and see if that helps. if so, you need to clean the air intake. probably full of dirt dobbers or wasp nest. check for fuel flow from tank to carb. have you set the governor rod length. it should be off half a hole with the gas wide open and engine not running.
FWB in SK
02-09-2008 21:24:59
Had similar problem with AR . Turned out was a leaking manifold gasket. Just a thought. Frank
FWB in SK
02-09-2008 21:37:33
 Re: Deere B in reply to FWB in SK, 02-09-2008 21:24:59
Spray some WD 40 around the intake manifold while tractor is running and see if it makes a difference. Frank
Wilamayb
02-09-2008 20:06:29
Ignition problems can make an engine to funny things and cause symptoms that would not be expected.
I would dare to say that you are not out of time unless you have had the tractor apart. Generally these things dont just get out of time.
I dont know the vintage of your B, so I dont know what type of ignition system you have? For mag and dist: they both need a good set of points with shiny contacts gapped to .017, a good condenser and good plugs gapped to around .030. To check spark you can get a good plug, open it up to around .060 then gound the plug with the igntion enabled roll the engine over. Did the spark jump the gap? If so you most likley have a spark that will start the tractor.
If you have a mag with a weak spark it is very possible that it has weak magnets which need to be re-magnetized.
If this tractor has not ran in a while I"m thinking you may have a valve stuck open? There is two ways to check. You can remove the valve cover to check, or you can run a compression test.
Sam from WA
02-09-2008 21:14:00
 Re: Deere B in reply to Wilamayb, 02-09-2008 20:06:29
we quit usin the tractor about 5 years ago when we bought a much newer 2550. the B we have is a 1948 model with a Wico XH magneto. we have had the mag totally reconditioned and it is throwing good spark. the tractor surges very badly when it shouldn't, because then ,agneto is timed right, the carb is clean and functioning, but the engine will not run properly for anything.
Kurt_JDB
02-10-2008 04:54:48
 Re: Deere B in reply to Sam from WA, 02-09-2008 21:14:00
Have you checked the throttle and governor linkages to see if they are binding anywhere? I would take them all off, make sure the governor arm moves freely, and then put them back together. Something may have gotten bent or rusted up.
Kurt
