2-cyl Dead on Occasion
wolfman
02-09-2008 18:08:12
About one time in five when you go to start my 520 you get the sound of silence. New cables, good battery, new ignition switch; Usually starts very quickly-but every so often complete silence. Any ideas? Thanks in advance.
CLW
02-11-2008 21:20:24
 Re: 2-cyl Dead on Occasion in reply to Andy Motteberg, 02-09-2008 18:08:12
I also think I would look close at the starter. Check to see if it has power to the starter. If so then tap on the starter with something with the starter engauged. Sounds like a bad or dirty contact or a dead spot on the starter.
jd b puller
02-11-2008 18:41:25
 Re: 2-cyl Dead on Occasion in reply to long hauler, 02-09-2008 18:08:12
wolfman said: (quoted from post at 21:19:22 02/11/08) CLW, I think "all of the above" is the best answer. I do usually rock it back or forward in about 4th gear. I think the jarring helps as opposed to the turning it over. No noise as when a starter is not engaging-no zing, nothing. I did put a new ground cable & attached it outside the battery box to a frame (new bolt) after grinding paint off. I now must check starter connections. Weather has been nasty here of late. Thanks, wolfy.
Pull the flywheel shielding out of the way so you can see what's going on down there. When you hit the starter, is it actually engagine, or is it hitting the ring gear and not engaging? That would make sense if there's no noise but you still have lights and rocking it back and forth makes it start.
CLW
02-11-2008 06:52:25
 Re: 2-cyl Dead on Occasion in reply to Mike M, 02-09-2008 18:08:12
wolfman, when it is dead, what do you do to start it. Do you pull it, rock it in gear, move something around, cuss it, or does it fix itself?
wolfman
02-11-2008 17:19:22
 Re: 2-cyl Dead on Occasion in reply to CLW, 02-11-2008 06:52:25
Kris A NC
02-10-2008 06:12:29
 Re: 2-cyl Dead on Occasion in reply to wolfman, 02-09-2008 18:08:12
I had the same thing with my '51B. I did everything below and even rebuilt the starter and generator. I had my battery grounded to the battery box. However, the battery box bottom and the spot where it mounted to the tractor were both painted. Took a grinder to them both, sprayed with wd-40 for rust prevention and bolted her backup. I have had smooth starting for 2 years now. I am not sure how a 530 grounds whether to the box or to the frame, but this was my issue. Hope it helps.
Kris A NC
John T
02-09-2008 20:25:06
First thing I would do is remove clean n wire brush then reatatch each n every battery n starter n switch n ground cable connections...Next, Id remove n check the starter switch. If its contacts are burned n pitted it should be replaced. If they are okay see if the copper starter post under the saddle switch is burned n pitted. If so one may file n wire brush n clean it up which may help but if its in bad shape it needs replaced.
HOWEVER if the battery n cables n switch n starter post are alllll llll good see if the battery voltage drops drastically and/or the lights dim dim wayyyyy down when you try n start her which says the starter motor may be bad unelss its mechanically stuck/jammed into the flywheel.
If the lights dont dim or the batery voltage dont drop but she just dont crank it can still be a bad switch or starter post as I noted above or a bad starter.....
Make sure the starter rod n linkage is okay such that depressing the start pedal fully engages the starter switch n it bottoms out.
John T
RobMD
02-09-2008 20:17:30
If you're still using the orginal foot starting, check the contacts in the starter switch and starter post.
Tom43
02-09-2008 18:48:21
Hook a voltmeter across the terminals of your battery(the terminals not the cables) and the voltage should not fall below 10 volts with the starter depressed. If this happens your battery is either discharged or bad. If voltage stays up, take the plate off under the tractor and put the negative lead of the voltmeter on the starter terminal and the positive lead of the meter on the tractor frame. Voltage should be essentially the same as what you measured at the battery. If it isn't you have cable or connection problems. If it is you need to the negative lead on the starter frame and the positive lead on the positive terminal of the batttery where you should read 0 volts. If not you have cable or connection problems. If you pass all these tests the starter needs to be removed and checked. Be sure to check the little mechanical switch on the starter. All these tests need to be done with the starter depressed. Sorry there isn't an easier way.
Dave in SV
02-09-2008 18:29:58
When it is "completely silent", have you checked to see if other electrical items, like the lights, work? Maybe knowing this will somewhat cut the system in half: either there's a complete DC failure (if everything is dead, including lights, etc.), or the problem is only related to the starter circuit (if other things like the lights do work even when you are experiencing "silence").
Does the 520 use a starter switch and solenoid? My old A does not... it uses a mechanical contactor that passes heavy current directly to the starter motor (taking the place of a solenoid).
wolfman
02-09-2008 20:27:07
 Re: 2-cyl Dead on Occasion in reply to Dave in SV, 02-09-2008 18:29:58
Forgot to mention-sometimes when no starter sound it'll have working lights, sometimes not. that's why I replaced ground cable and terminals and ignition switch. Now I must check starter connections. Yes, the original foot starter button.
Lee B
02-10-2008 00:49:12
 Re: 2-cyl Dead on Occasion in reply to wolfman, 02-09-2008 20:27:07
Use a small angle grinder on the place where the ground strap bolts to the frame to get past the paint, rust, and/or corrosion there. New cables don't work when they are bolted to paint you know. Run a tap into that bolt hole and use a new bolt too.
Starter grounds will sometimes surprise you at how bad the connection can really be. I drove a GMC Brigadier Water Truck for a while which had a 6-71 Detroit 2 cycle diesel engine in it. The starter was a massive thing with three 3/4" mounting bolts with 12 point heads on them. All three of those had to be cranked down to 150 ft/lbs minimum or the starter couldn't ground itself enough to even groan. Otherwise, pure silence - just like yours, hmmmm?
Wire brush the starter's mounting face, again tap the bolt holes and use new bolts. I had to eventually rebuild the starter switch on my A using a copper bolt from a soleniod that I wasn't ever going to use for anything else. I got lucky and it all worked out for me.
My problem was both a dirty frame connection in the battery box and a stripped copper bolt on the foot starter switch which then wouldn't squeeze the battery cable to the rest of the circuits good enough to pass adequate current.
