420 hydraulic Pump
Andrew M
02-09-2008 16:41:19
The hydraulic pump on the 420 is whining and leaks abit. Might be time for a rebuild. Are parts still availabe from JD or does anyone do a exchange for a rebuilt pump?
CPeter
02-09-2008 17:05:54
 Re: 420 hydraulic Pump in reply to Green Mister, 02-09-2008 16:41:19
Andrew M said: (quoted from post at 20:41:19 02/09/08) The hydraulic pump on the 420 is whining and leaks abit. Might be time for a rebuild. Are parts still availabe from JD or does anyone do a exchange for a rebuilt pump?
The seals and bearings are still available from Deere. I did one last summer and the prices were reasonable. Some of the bearings are available from local bearing shops of your local Harley Davidson dealer as they use them in the transmission on som Harleys. The whine maybe from a scution line leak. You can get those seals from Deere, too. What model is it?
CPeter
AndrewM
02-09-2008 19:33:48
 Re: 420 hydraulic Pump in reply to CPeter, 02-09-2008 17:05:54
It is a 420W. I will check the seals on the suction line. Thanks
