JD 40 Fan Bearing
G.S.
02-09-2008 14:57:03
I have a JD40C with a noisy fan bearing. I was told that it takes a water pump bearing. Does anyone know the part number of that bearing? I'd like to have the new part ready to be installed, so the tractor is not disabled for to long.
Thanks G.S.
Dave H
02-10-2008 06:18:43
 Re: JD 40 Fan Bearing in reply to G.S., 02-09-2008 14:57:03
Depending on where you live and how far out and if when you knock the old bearing out you can get a number off it, I usually take the easy way out on getting new ones.
There is a local bearing and seal place called Motion industries. I call them on the phone, give them the number and the bearings arrives on the overnight truck that runs every night and their price is very hard to beat.
Just a thought on bearings.
G.S.
02-10-2008 13:11:16
 Re: JD 40 Fan Bearing in reply to Dave H, 02-10-2008 06:18:43
I've never taken one of these apart, it sounds like you've done a few. Do I need to grind off the rivots and remove the fan to get the pulley off the bearing? If so, how do I reattach the fan? Thanks! G.S.
8e3k0
02-09-2008 19:35:08
The part number is M74707 and are readily available from Deere. Have replaced a number of them and work well. Ellis
G.S.
02-10-2008 12:45:17
 Re: JD 40 Fan Bearing in reply to 8e3k0, 02-09-2008 19:35:08
Thankyou very much for the info. That saves me a great deal of research. G.S.
Mike M
02-09-2008 19:40:25
Just got back from the archives. I got that number there,but I think you name came up to ? Sounds as though it worked out for you. Everyone needs to write this in their parts books so it isn't lost. I sure can't figure out why Deere didn't put it in there ?
G.S.
02-10-2008 13:13:55
 Re: JD 40 Fan Bearing in reply to Mike M, 02-09-2008 19:40:25
Thanks! G.S.
Mike M
02-09-2008 19:27:53
Somewhere here in the archives is that number. I posted it here. I never have much luck with the archives searches either. It was a common bearing JD dealers usually stock and I was thinking it was the same a in one of the mower deck double idlers. I replaced the one in mine that's how I came up with the number. I can repost it but it may be a few days.
long green line man
02-09-2008 16:29:21
JD parts shows that bearing available only as complete pulley & fan assembly,PART# AM1810T. you could try bearing from 420 water pump looks very similiar, dealer might have on hand part#JD8549T. good luck!
G.S.
02-10-2008 13:16:17
 Re: JD 40 Fan Bearing in reply to long green line man, 02-09-2008 16:29:21
Thanks! G.S.
