JD 4555 or 4650?
JDBrian
02-09-2008 06:42:47
Which should I buy? Both are 2wd and powershift. The 4555 has 8920 hours and the 4650 has 9000 hours. They are both in good condition. The 4555 is $30,000 and the 4650 is $28,000. The 4555 has axle duals, the 4650 doesn't have duals. Are the asking prices reasonable? Also, what are the strong and weak points of both tractors? All opinions are appreciated.
HeyPigFarmer
02-09-2008 10:40:22
 Re: JD 4555 or 4650? in reply to JDBrian, 02-09-2008 06:42:47
They are basically the same tractor. The 4650 is intercooled and is 10hp more. The 4555 is rated for a few more pounds on the 3pt.
My 2 cents, go with the one that has the better tires, the duals and is in the better shape of the two. Price seems a bit much for tractors with that many hours, but depends on where you are located.
I don't know where you are located but right now on ebay there is a 4850 2wd for 20,500 but it doesn't state the hours. Good luck.
