1949 J0HN DEERE A
GENE johnson
02-09-2008 04:37:25
BUCK EYE AL, THANKS FOR ALL THE GOOD INFO. WHEN I GET OVER THIS CHEMO I AM GOING TO GET STARTED ON THIS TRACTOR. IT RUNS GREAT, LOVE TO HEAR IT.YESTERDAY I PULLED ON THE LIGHT SWITCH,TRACTOR NOT RUNNING AND IT MOVED THE HAND ON THE AMP METER TO THE RIGHT. THEN I CHECKED THE BAT. WITH A VOLT METER , TRACTOR NOT RUNNING AND THEN STARTED THE TRACTOR. THE METER SHOWED MORE VOLTS WITH THE MOTOR RUNNING. THIS IS WITH THE BATTERY HUCKED UP NEG. GROUND LIKE I GOT IT. WHER DO I GO FROM HERE, JUST REVERSE THE BAT. ONLY OR DO I NEED TO RE EXCITE THE GEN. LIKE YOU DESCRIBED. THANKS GENE
Andy Motteberg
02-10-2008 13:03:58
 Re: 1949 J0HN DEERE A in reply to GENE johnson, 02-09-2008 04:37:25
Hi Gene, I have a 1949 A too I'm restoring. It still needs a lot of work, but I hope to have it running in the Spring.
Andy.
Dave in SV
02-09-2008 14:03:39
My guess is that the tractor used to be positive ground, and when it was converted to negative ground, the leads on the ammeter were not swapped.
If I'm right... I got lucky. If I'm wrong, forgive my novice attempt.
