Ammeter gauge bouncing on 1950 B
Pat in MI
02-08-2008 07:34:16
My ammeter bounces from 0 to the max on the gauge when running. Is this gauge bad? I have a meter, how do I check the output of my generator?
Thanks for your help. Also, I accidentally crossed the white and black wires running to my lights and ammeter, and now the lights don't work. What might I have done?
Texasmark
02-09-2008 07:19:03
 Re: Ammeter gauge bouncing on 1950 B in reply to Pat in MI, 02-08-2008 07:34:16
Replace your brushes and dress up your armature..... a little 400 grit emery paper should do the trick. The brushes have worn down to the point where the springs can't exert enough pressure to hold the brush against the armature and apparently the armature has a rough surface (scored) which causes the brush to want to bounce.
After you do that, if you still have a problem then investigate your gauge.
Mark
Bob
02-10-2008 00:40:08
 Re: Ammeter gauge bouncing on 1950 B in reply to Texasmark, 02-09-2008 07:19:03
Sandpaper is the stuff to use. Emery paper is NOT recommended.
Texasmark
02-10-2008 06:45:06
 Re: Ammeter gauge bouncing on 1950 B in reply to Bob, 02-10-2008 00:40:08
Why not? cause of metallic aggrigate composing the abrasive? I always remove any particles when finished and clean up the insulators. Have never had a problem. I prefer emery because I can get a smoother, more uniform surface on the armature with a piece of 1" wide emery about a foot long, pulling it back and forth.
Mark
Andy Motteberg
02-08-2008 22:57:22
Just buy a new gauge and see if it works.
