2140 load sensing shaft?
JFoshee
02-07-2008 19:15:13
I'm working on a 2140 that is leaking transmission oil at the shaft where the 3 pt. arms attach at the bottom. (Please excuse if I'm not using the right termaoligy, I usually work on construction equipment.)I removed this shaft and will replace it and the bushings in the housing. I was looking for some advice on removing the bushings and any other pointers I should be aware of when installing the new parts. Thanks ahead of time for any info.
Jake Winn
02-07-2008 21:25:51
 Re: 2140 load sensing shaft? in reply to JFoshee, 02-07-2008 19:15:13
What i have done before is take the seals out of the bushings, put a woodruff key into the seal groove that is as close to the ID of the bushign as possible, then take the old load shaft from the tractor and slide it through the opposite side and into the bushing and drive it out with a hammer. Do the same for the other side. When you put the new bushings in, use some high strength loctite. Good luck
