4630 steering wander
wilson2
02-07-2008 14:45:13
I have a JD 4630 that I have been fighting an issue with wandering steering at road speeds. I have replaced the steering pump (under the dash), the spool valve and still have the same issue. We have checked the alignment two times and it is fine. Wheels and tires are good and straight. We honed the spool valve and made sure it was not sticking. I have trying everything I know, so what am I missing? Same with or without a load...
2cylfarmer
02-07-2008 18:40:30
 Re: 4630 steering wander in reply to wilson2, 02-07-2008 14:45:13
I just went through the same thing. We ended up re-building the steering motor at the front of the tractor. Quite a chore, but much easier & safer on the road now.
mattd
02-07-2008 17:07:40
how bad is it? jack the front end off the ground and make sure your tie rods are tight. if they are then reseal the steering motor pistons. it sounds like you have a late 30 series if you have a metering pump and steering block. the valve spool is a machined fit to the block so if you removed any material when you honed it then it may be leaking.
