JD 60 Gas Tank
SteveJD60
02-06-2008 18:34:48
I have a John Deere 60 gas. The gas tank neck has started to leak. The neck appears to be a separate piece from the tank. There appears to be a gasket between the pieces. Before I damage something; what is the best way to re-seal the neck connection and replace the gasket?
I haven't taken anything apart yet.
Thanks for your help.
SteveJD60
02-07-2008 17:00:52
 Re: JD 60 Gas Tank in reply to SteveJD60, 02-06-2008 18:34:48
Thanks for the help guys. The tank has obviously leaked before as there"s some remaining sealant around the neck that looks like an old gasket. It was enough to confuse me. I will proceed to clean it out and try either the solder or JB weld approach.
Steve
F-I-T
02-07-2008 10:08:05
third party image
The neck is a separate piece, but there is no gasket. The neck is soldered to the tank. Any radiator shop can solder that for you, or you can swish the tank to fume-free, and use a non-flame heat source such as a soldering copper and re-solder/re-seal it yourself. The gasket as shown in the parts book is inside the cap.
HTH
Frank
farmboy169
02-06-2008 19:27:55
You could try some JB Weld. I put some around the gas tank neck on my D and seems to be working so far. That has been about a year now. Just an idea. Good luck.
