How to remove a loader without another tractor?
lekander883
02-06-2008 14:55:16
John deere gas 1020 with 48 loader. How can a I remove my loader without having another tractor to lift it up as I drive out? I cannot support the loader and back out because the wheels will hit the jack stands. I dont have anything strong enough to hoist it up. Has anyone figured out an easy way to remove a loader?
Kevin Schmidt
02-06-2008 18:26:42
 Re: How to remove a loader without another tractor? in reply to lekander883, 02-06-2008 14:55:16
Done them before by putting the loader bucket against a tree or large post and a couple of chains to a comealong tied about 4 or 5 feet off the ground on the post. Works ok and faster than making some brackets, safer then the handyman jacks
P Browning
02-07-2008 03:17:20
 Re: How to remove a loader without another tractor? in reply to Kevin Schmidt, 02-06-2008 18:26:42
Come-alongs are NEVER safe for lifting! (PatB)
johns48jdb
02-06-2008 17:49:29
you can build a set of stands where you make a three legged base and one upright out of sq tubing. inside the sq tubing upright drill a hole that will line up with holes in another piece of sq tubing that fits inside the upright. that makes it sturdy and adjustable in height. you can drive across one of the three base legs if necessary. to do it right build yourself a stand out of 6 x6's set in concrete and then use a 6 inch piece of channel across those two post to support the weight with. turn the cannel on its side and bolt it to the 6 x 6's with 1/n inch bolts that go all the way through and big washers under the head of the bolts on the back side of the 6 x 6.
JMS/.MN
02-06-2008 17:15:11
Five pieces of pipe. Two A-frames, connected by an overhead pipe. Lift/support with come-a-long. Overhead pipe is long enough to straddle the tractor. Or two trees, growing about 7 feet apart!
Gerald J.
02-06-2008 16:17:39
I believe the 48 came with stands that fasten to the loader fairly securely and flare out to clear the wide tractor front. You need the operator's manual before you hurt yourself, the tractor, and the loader.
Gerald J.
msb
02-06-2008 18:55:41
 Re: How to remove a loader without another tractor? in reply to Gerald J., 02-06-2008 16:17:39
Gerald is right. Get an operator's manual or a parts manual and weld up a pair of stands. BE CAREFUL !
old
02-06-2008 15:18:46
I've done it before with 2 sets of jack stands. You jack it up and hold it as high as needed to clear the axle then back out half way and set the 2nd set of stands under it and pull the first set out and back out
lekander883
02-06-2008 15:21:37
 Re: How to remove a loader without another tractor? in reply to old, 02-06-2008 15:18:46
Good idea. I'll try that..... ....
old
02-06-2008 15:30:11
 Re: How to remove a loader without another tractor? in reply to lekander883, 02-06-2008 15:21:37
BTDT just be very careful because jack stand can lean and then fall. I like long wood blocks so it can not fall
