Backspin starting a unstyled John Deere
Mark Poss
02-06-2008 11:00:39
A friend of mine was at a tractor show this summer, and saw a man turning the flywheel clockwise to create a backspin to start the tractor. Has anyone ever seen or heard of this?
Kent Petersen
02-06-2008 20:16:08
 Re: Backspin starting a unstyled John Deere in reply to Mark Poss, 02-06-2008 11:00:39
the fix on 70 and 720 was simple deere installed a ckeck valve in the fuel return side of pump rack ,this way if it went back words no fuel gets to the pumps. as two tuning backwords to pull in more fuel you would turn about 240 degress to open intake to get more fuel. i us the choke on mine
Kent
old
02-06-2008 20:47:50
 Re: Backspin starting a unstyled John Deere in reply to Kent Petersen, 02-06-2008 20:16:08
I do the rocking back and forth with it choked, then unchoke it and most of the time it fires right up as soon as I puller it past the 2nd impulse trip. Had an old man show me that a couple years ago and it works real well and sure has saved my back and arms
Mark Poss
02-06-2008 17:15:29
My friend said they would turn the flywheel clockwise and then the flywheel would turn counter clockwise starting the tractor on its own.
P Browning
02-06-2008 19:39:58
 Re: Backspin starting a unstyled John Deere in reply to Mark Poss, 02-06-2008 17:15:29
Your friend -- I think -- has been pulling your leg. Having the magneto set to fire too early will cause the flywheel to kick in a reverse direction, but no way will the US "A" tractor engine start like that. Having ignition set too early has given short life to many a starter out there -- so I have been told, and surely that's easy enough to fathom. (PatB)
MSD
02-06-2008 14:36:47
Correct me if I'm wrong, but didn't the early 720 diesels have a problem that they could run backwards? Seems they had to modify the cam so it wouldn't do it if I remember right.
wilamayb
02-06-2008 16:16:31
 Re: Backspin starting a unstyled John Deere in reply to MSD, 02-06-2008 14:36:47
Yes the 70's and early 720's were know to have 6 reverses at times. LOL The two stroke GM diesels like to do the same.
I guess the handstart tractors would not likley do this since the mag would not snap, and niether would it intake gasoline.
I guess if modern fuel injected spark ignition engines used direct injection they could also be reversible.
I sit and ponder way too much!
old
02-06-2008 11:10:16
Yes I rock mine back and forth when I want to start my B. rocking it that way but not going past compression sucks in more gas so most of the time they will start on the first pull if all is well
jd b puller
02-06-2008 18:12:32
 Re: Backspin starting a unstyled John Deere in reply to old, 02-06-2008 11:10:16
Old, I don't understand, if you're on the compression stroke, how could rocking it backwards suck in more fuel? both valves are closed.
old
02-06-2008 19:09:26
 Re: Backspin starting a unstyled John Deere in reply to jd b puller, 02-06-2008 18:12:32
By rocking it back and forth you open and close the intake valve so it sucks more fuel in. That valve doesn't close till just before it goes to the point the impulse trips on the mag. Or in other words that rocking is on the intake stroke. You can even here it sucking fuel when you are doing that
jd b puller
02-06-2008 19:22:38
 Re: Backspin starting a unstyled John Deere in reply to old, 02-06-2008 19:09:26
Got it, you are doing it on the intake stroke, not the exhaust stroke.
