2955 4x4
RLH
02-06-2008 07:48:51
tell me good and bad about 2955 4x4 .will it replace a 4020 thanks
low budget
02-08-2008 03:24:55
 Re: 2955 4x4 in reply to RLH, 02-06-2008 07:48:51
The 2955 is a good tractor. Probably a better engine than the 4020, more responsive. Whether it is a good replacement for 4020 will depend on the intended use. The 2955 is a utility tractor and has a somewhat lighter transmission, rear end and final drives. My opinion is a 4020 is more tractor, although the mechanical front assist on the 2955 would be a big plus.
Sam from WA
02-06-2008 08:44:39
2955 is one of the best tractors deere built in the 90 horse range. excellent tractor with good power, i use one as a loader tractor, but use it in the field when we need it. i believe the 2955s were rated at 86 horsepower, but when in the field it seems like they have 130. both trannies were great, ours has the partial-range powershift, not the creeper. we have a 2550 with a creeper, great transmission for what we need it for (planting, culitvating, rototilling, spraying) about the only thing we"ve had to do on the 2955 was change oil, and replace the starter. our 2955 has over 10,000 hours on it and has not required more than normal maintenance.
PreciseFarms
02-06-2008 18:55:54
 Re: 2955 4x4 in reply to Sam from WA, 02-06-2008 08:44:39
We have one too. A two post canopy and 265 loader. It has been abused and its ugly but it is a great machine. It has been used a great deal to load bulk fertilizer so you can imagine what that has done. No lights work on it, the switch is even stuck, and there is a lot of rust. Most of the problems with it can be attributed to the fertilizer eating at it and that isn't the tractor's fault. It has almost 3000 hours on it with only a clutch and starter being replaced. The clutch would still be in it if not for the loader work or had it been a wet clutch. The only reason I could see trading it would be for a cab and reverser but I would keep it to abuse a little longer because it always looks ready for it. You wouldn't believe some of the trees we've pushed with it or the things it has been used to move.
