Help with rebuilt 2010 starter
DPN
02-05-2008 17:18:15
I just bought a 2010 to restore for kicks. I had the starter rebuilt and the solenoid was replaced. I am having problems connecting it. I am sort of learning as i go so bare with me. the terminal markings are different from the original. the large post in the solenoid I assume is the negative terminal from the battery - remember this is a positive ground system. the two smaller posts are labeled S and R. The tractor has two additional wires one is purple and goes to the generator, the second is of a larger gauge and red and according to the scematics goes to the voltage regulator. what terminal is proper for each wire? I have tried various combinations and had no success. no sound, or movement. I can jump the large post to the S terminal and get the motor to turn. I am beginning to suspect a bad key switch. Any pointers. I appreciate any help offered
Bob
02-05-2008 22:01:27
 Re: Help with rebuilt 2010 starter in reply to DPN, 02-05-2008 17:18:15
"S" = START.
"R" = "Resistor bypass"... bypasses the ignition ballast resistor (IF USED) for a hotter spark during cranking.
DPN
02-06-2008 10:20:48
 Re: Help with rebuilt 2010 starter in reply to Bob, 02-05-2008 22:01:27
Bob, then if my battery cable goes to the main post on the starter, the purple wire which is from the neutral saftey switch would then go on the "s" terminal. Where would the lead from the voltage regulator go. The secematic says to the battery terminal, so I assume this is again routed to the main post on the starter? This may be obvious but i'm being cautious.Its a diesel so i'm fairly certain the "r" termianl isn't used.
thanks for your help
jdemaris
02-06-2008 14:52:47
 Re: Help with rebuilt 2010 starter in reply to DPN, 02-06-2008 10:20:48
The "R" terminal isn't used on any of the 2010s, gas or diesel. In fact, many didn't even have the termimal since some used Prestolite starters instead of Delco.
Gas tractors used a special ignition switch with the resistor bypass built right into the switch.
I'm going to assume you've got a 12 volt 2010 and not an early 24 volt with the special series-parallel switch.
Most early 12 volt 2010 diesels go like this:
Blue wire is the start wire.
Red wire goes from big stud on solenoid to "B" terminal of voltage regulator.
Black wire goes from same big stud on solenoid to hour meter - if you have one.
The last and newest 2010 diesel goes like this:
Purple - S terminal on solenoid to ST of IGN switch.
Red - big post on solenoid to "B" on regulator
DPN
02-06-2008 15:29:09
 Re: Help with rebuilt 2010 starter in reply to jdemaris, 02-06-2008 14:52:47
Thanks for the information. I really appreciate it.
Bob
02-06-2008 13:02:55
Yes, the charging lead would go to the large stud where the battery cable "lives".
It SHOULD have a much larger ring terminal than the other wire.
And, yes, you're correct, a diesel wouldn't use the "R" terminal.
DPN
02-06-2008 13:31:53
 Re: Help with rebuilt 2010 starter in reply to Bob, 02-06-2008 13:02:55
Thats the problem no connecters were on the leads. In addition the starter was removed by someone else. Had I removed it, I would not be in such a fix. Thanks for taking the time to answer what i'm sure are trivial questions.
DPN
