3010 three point raises very slowly
skip33652
02-05-2008 16:58:12
in the it manual it shows an adjustment for raising and lowering speeds but this tractor does not have the adjustment for the "raise " is there one hidden somewhere?should I add or subtract shims under the plug on back side any other ideas?? I know I probably have a few otherinternal leaks but this is where I am starting thanks Paul
msb
02-06-2008 11:00:09
 Re: 3010 three point raises very slowly in reply to skip33652, 02-05-2008 16:58:12
Pressure should be 2250 even at idle. There is no raise adjustment. With the 3 point fully raised, shut the engine off and see how long it takes to settle. That is the first place to start to eliminate a bad o-ring on the raise piston. It should hold the raised position for at least 2 or 3 minutes before it begins to settle. The thermal relif valve might need reseated Its located on top of the valve body at the rear. Remove the plug and spring. Place a punch on top of the valve and give it a few light raps with a hammer.
Tx Jim
02-06-2008 03:41:25
 Re: 3010 three point raises very slowly in reply to Roxie, 02-05-2008 16:58:12
Skip have you checked your stand-by pressure? Jim
skipp33652
02-06-2008 05:53:42
 Re: 3010 three point raises very slowly in reply to Tx Jim, 02-06-2008 03:41:25
pressure is good it comes up a bit slow but gets to 2100lbs. at idle.Paul
Gerald J.
02-05-2008 17:08:46
Check that the full stroke of the control handle gets to the control valve under the seat. The push pull cable is prone to rusting and stretching.
Gerald J.
skip33652
02-05-2008 20:01:38
 Re: 3010 three point raises very slowly in reply to Gerald J., 02-05-2008 17:08:46
If the handle did not go all the way up the three point would not go all the way up but would go to that point at correct speed and yes fluid lvel is up.Paul
TEXASJ
02-05-2008 17:04:58
Check the hyd. fluid level?
Texasmark
02-09-2008 07:46:45
 Re: 3010 three point raises very slowly in reply to TEXASJ, 02-05-2008 17:04:58
Easiest way to do that is to listen to the hyd pump at engine startup..... if like the 4000 series. If the fluid is low, the pump will rattle for a period before it gets quiet.
Mark
Texasmark
02-09-2008 07:48:49
 Re: 3010 three point raises very slowly in reply to Texasmark, 02-09-2008 07:46:45
Low ambient temperature could cause slow lift due to the increased viscosity of the fluid.
Mark
