4020 starting fluid aid
jdjerry
02-05-2008 07:34:13
Last week we had -50 below wind chills and my 4020 that was sitting outside but the tank heater was plugged in would not start. I gave it a squirt of starting fluid in the air intake because the factory one in the dash did not seem to work and it fired up. When the weather warmed up I took off the dash panel to check the line for leaks or kinks and not seeing any thing wrong I took the line off fron the intake and fluid sprays through the line. I squirted starting fluid in the hole in the intake with the tractor running and it does nothing. I took the bowl off the oil bath and sprayed starting fluid in the air cleaner with the tractor running and that worked as well as the intake stack. I sprayed starting fluid all around the intake with the tractor running and no change. I have had this tractor for years and use it every day in the winter to feed cows with. I keep it plugged in and it sits outside. I know it is wore out but it starts down to about 25 degrees without being plugged in. Any ideas of why the factory set up will not work?
mjbrown
02-05-2008 10:09:58
 Re: 4020 starting fluid aid in reply to jdjerry, 02-05-2008 07:34:13
I have a 4230 which needs help starting most of the time and I prefer to spray on the precleaner screen because it clatters a lot less than using the either injector.
Bob
02-05-2008 07:38:38
Likely, the little brass nozzle screwed into the intake manifold is clogged.
