First reduction gears
Paul from MI
02-04-2008 19:33:46
Restoring a 37 B. I find more gear noise in the first reduction gears than on my other Deere's. The noise seems to follow engine RPM, not tractor speed. It increases at lower speeds and nearly goes away at full throttle. If I drive on a downgrade(no load) the noise goes away at any speed. Also goes away as soon as I disengage the clutch. The noise seems the same in all gears, including reverse. I can't see any visible wear on the gfear teeth and they roll against each other smoothly. I have replaced all of the bearings on the input shaft and sliding gear shaft, which helped some. I am using 10W-40 engine oil, temps here are around 25F. Will changing to thicker oiul, like 20W-50 help? I would change both first reduction gears if I could eliminate the noise. How can I tell if the ones I put on are any better than what I have? Anybody got any ideas?
Thanks,
Paul
NW MO Poppers
02-06-2008 08:11:03
 Re: First reduction gears in reply to Paul from MI, 02-04-2008 19:33:46
The thicker oil may help some. One thing you may want to check is the clutch bearing/ bushing. It too can make lots of noise, and sounds like the first reduction gear. Something to think about.
