2510 live transmission pump?
Bill Wy
02-04-2008 10:48:32
Does the JD 2510 have a live transmission pump? I was told that if the transmission pump is not live, when you push in the clutch the transmission pump stops feeding fluid to main hydraulic pump. This will tend to starve the main pump when you use the loader with the clutch in. The person I spoke to said this was true with the 10 series tractors but did not know about the 2510 tractors. Thanks, Bill
Gerald J.
02-04-2008 11:15:07
 Re: 2510 live transmission pump? in reply to Bill Wy, 02-04-2008 10:48:32
If its like the bigger new generation tractors of the era, there's a check valve between the transmission pump and the oil cooler/reservoir up front by the main hydraulic pump that keeps the front pump supplied with oil for 15 or 20 seconds at full flow, longer for ordinary flows. When that check valve wears, you loose hydraulics shortly after pushing in the clutch, and then loose steering, brakes and such too in the bigger tractors. There is a service information that suggests converting an outside elbow to replace that check valve. I have a web page about it. And it applies to the 2510..
Its been applied to dozens of tractors that I know of including my 4020 and it works. Solves that loss of hydraulics problem with the clutch pushed. My 4020 can sit months, and I can start it holding the clutch pedal down and lift the loader before letting the transmission input shaft turn at all.
Gerald J.
Mike M
02-04-2008 11:00:06
Now if you happen to have a powershift then it is live and won't do that.
LarrySTN
02-04-2008 10:58:23
This is also true of the 2510 syncrorange.
Bill Wy
02-04-2008 11:12:16
 Re: 2510 live transmission pump? in reply to LarrySTN, 02-04-2008 10:58:23
Larry Are you saying that the syncro does have a live transmission pump and works like the power shift?
Bill
LarrySTN
02-04-2008 15:48:54
 Re: 2510 live transmission pump? in reply to Bill Wy, 02-04-2008 11:12:16
Bill, Its true the 2510 syncro trans tractors will lose hydraulics if the clutch is depressed, just as with a 3010, 3020, 4010, 4020 & 2520. The loader should have a return to hyd pump though and if everything is working as it should, the tractor should not lose pressure during the short time the clutch is depressed. Most of the hydraulic functions of the tractor are to return oil to the hydraulic pump, which in theory should keep it from loosing pressure. Now for practical application....most of these old tractors have internal high pressure oil leaks which will cause a lose of function when the clutch is down.
