1st born, 2nd mortgage or easy fix? JD 2020
ShepFL
02-03-2008 17:15:57
Plowing with JD 2020 with a 2 bottom disk plow (20"). Soil is light and sandy. While plowing tonight the RH lift arm that mounts under the tractor came loose. The rod that runs thru the rear end is now extended 14" on the left side and slipped inside casing.
Can this just be realigned and "driven" thru and back out the right side? Any special tolerances etc. I need to look out for?
Meanwhile I will be researching the archives and other areas right now for repair information.
johns48jdb
02-04-2008 05:08:46
 Re: 1st born, 2nd mortgage or easy fix? JD 2020 in reply to ShepFL, 02-03-2008 17:15:57
my neighbors forign made jd was leaking at the same pin. look to see if there isn't some seals there. i'd replace them while your into it. chance are that the one that slipped out runied that seal any way. don't pull the pin all the way out. i don't know if it slides through anything on the inside or not so i just slid it back in enough to get the seal out.
powertech84
02-03-2008 19:27:26
sounds like your talking about the load depth shaft.as long as nothing broke it can be gently pushed back through. no need to hit, slips back through.pin it up and go. as long as the three point works, not neccessary to adjust.
ShepFL
02-03-2008 21:11:27
 Re: 1st born, 2nd mortgage or easy fix? JD 2020 in reply to powertech84, 02-03-2008 19:27:26
Thanks you sir! I know nothing of JD and this shocked me. On my other rigs the lift arms are mounted on external studs etc. When I set the plow back down and just started to take off it "felt" funny so I immediately stopped.
Climbed off to check things out thinking I lost a lynch pin and I seen hydraulic fluid just pouring out the RH hole. Lifted the plow and got back on the land and shut it down. I was thinking the same that this rod could be pushed back into place.
Thanks again and watch for updates.
ShepFL - still in the weeds. . .
JMS/.MN
02-04-2008 08:05:56
 Re: 1st born, 2nd mortgage or easy fix? JD 2020 in reply to ShepFL, 02-03-2008 21:11:27
Check the archives for some articles about replacing load shaft seals. Good step by step info here. There is also an aftermarket seal available that some say last much longer than the original Deere seals.
