Info on J.D. 60 tractor
Swane
02-03-2008 13:48:37
I am going to restore a 60 JD tractor, my Grandfather bought new, I found another 60 for parts. My question is the junk 60 has rear wheel cast centers with slots in cast, and my grandpa's has a solid cast, like a 'A'. My serial is 4320. I believe grandfathers is original, or should I change them? Thank you!
OCB
02-08-2008 16:51:18
 Re: Info on J.D. 60 tractor in reply to Swane, 02-03-2008 13:48:37
swane, the several years the 60 was build some major change were made in certain areas. Before you jump to far look at the parts manual and compare the old and new. Making a parts swap may require a bigger number of parts changed At S/n 6025403 a major change was made to the live PTO requiring a difference housing holding the Powertrol, Rockshaft and PTO clutch. At S/n 6021831 another group of changes were made. It appeared the 2 cylinder power was hard on all Live PTO parts.
The first production 60's had some changes that where direct swap like the wheels you mentioned, swap and go.
Enjoy your labors of green. clay
buickanddeere
02-03-2008 17:47:14
A 60 is a fine old tractor. If it has the optional live pto and powersteering.That and the duplex carb plus live hydraulics make it twice the tractor any A is.
The Dukester
02-07-2008 19:29:19
 Re: Info on J.D. 60 tractor in reply to buickanddeere, 02-03-2008 17:47:14
Yeah, a 60 is a lot more "modernized" than a late A, with just a little more power...but they sold a lot of A's in their day. You gotta admit the A was pretty darn good in it's time..1934 to 1952...that's 18 years. Sorta like comparing a Model A Ford to a Model T, the old T was pretty outdated when the A came along, but man, they sold a lot of them in their day. How does a 60,620,630 compare to a 3020? The 3020 came out only a little over 10 years after the 60.
Tom43
02-03-2008 15:44:48
The early wheels had problems with cracking. You might want to check the archives.
flying belgian
02-03-2008 14:30:02
The 53s had slots. 54-55-56 had round holes. Look up the vintage of yours and see which ones are right for yours.
