JD Alternator??
phil25
02-03-2008 07:08:17
Morning: I have obtained what i am told is a John Deere Alternator,[ doing a retro/conversion-fit to a russian,] the only part number on it is 100275, shaft is 5/8 fine thread, red B+ post, "W" post[ tach connection?] three terminal field connections? one of the three is a smaller male spade than the othere two male spades.
All things being normal, B+ =output and small spade switched 12v input, but i want to be sure as i do not have Jd equipment to check against [donor tractor/unit is gone], so i don't have a model number to refer to,any possible idea on the amp capacity of it?
tks
phil25
02-05-2008 09:05:54
 Re: JD Alternator final note in reply to phil25, 02-03-2008 07:08:17
Good Day to all: Now that the "free" alternator is junked, actually traded at a shop for a chev unit, proof there's money in [junk] parts:)
a little bit of machine work to make a double v-groove pully and all will be operational again, thanks for the help, hope to do the same for someone else, some day.
regards
phil25
02-03-2008 15:28:24
 Re: JD Alternator: new info in reply to phil25, 02-03-2008 07:08:17
Gentlemen: New info found under the brush holder unit is Magnet/Mare??[ the M being common to both words] with a horzitional H under the stamping.
Now the news is not good, i found the brushholder broken off on one side?? The leads from the sliprings to stator are shiny where they bend over to connect, and they hit the brushholder.
So my new not used alternator is used but broke from new, checked with the "older" operator and he remembered they had electrcial troubles when it arrived, and they[dealer] changed a lot of stuff,and this alternator was kept as a good but used unit.Then the tractor was sold off[ asset sale]
Mystery solved,now to check as to being cheaper to buy brusholder or salvage yard a chev unit.
And i did find the the two bigger spades are common to each other[same base] and there is a third spade[ capped off]next to the "W" terminal.
Many thanks to all, its a good day when a person learns stuff, i did.
tks
jdemaris
02-04-2008 06:52:59
 Re: JD Alternator: new info in reply to phil25, 02-03-2008 15:28:24
I find that horizontal H on all the Bosch stuff - I assume it's one of their logos since it appears right in the middle of the Bosch part-number.
All those replacment parts are easy to get if that's what you want. If you opt for a different alternator, the Delco 10SIs are easy to find for $20 each - but they are big and bulky and don't fit well in all tractors. If space is a problem, the more-compact Hitachis - found in many 1980s vintage Japanese cars work great and wire up exactly the same as the Delco 10SIs. The Hitachis are also better built and more rugged. Just about any 1990 or older Subaru will have one. The Delcos don't hold up in real farm use, but work fine otherwise. Year's back, we were converting many Deere tractors - taking the Bosch or Motorolas off, and installing the biggest Delcos we could find. That because some corn-planters drew over 40 amps of current at low engine speeds and the OEM alternators couldn't hack it. Later, Deere starting using the Delcos and we had a very high failure rate because they are not sealed and farm-dust ruins them. Then Deere tried putting screens on them, and finally gave up and used sealed alternators e.g. the Nipposdensos.
Bob
02-03-2008 19:10:03
 It's a no brainer.. in reply to phil25, 02-03-2008 15:28:24
It's a "no brainer". You should be able to pick up a "recycled" Delco for $10 to $20, and I've already showed you how to hook it up using a diode that will not cost you over $2.00!
TractormanNC
02-03-2008 17:21:20
"Mare????" Could it be "Marelli" or something like that? If that is what you have, it is a French made unit that was used on some Fords and is a PIECE OF JUNK. GET RID OF IT. If you can post a pic, Ican identify it if it is a Marelli (sp). I have changed enough of them to Delcos.
jdemaris
02-03-2008 07:55:34
 Re: JD Alternator?? in reply to phil25, 02-03-2008 07:08:17
Sounds like a Bosch alternator off a Deere. They were used on many german-Deeres sold in the U.S.
Bob
02-03-2008 09:31:28
 Re: JD Alternator?? in reply to jdemaris, 02-03-2008 07:55:34
jd,
Any ideas of the application you are referring to?
The Bosch units I commonly see have only a TWO terminal connector.
jdemaris
02-03-2008 10:29:13
 Re: JD Alternator?? in reply to Bob, 02-03-2008 09:31:28
I've got several sitting on my shelf that I took off of Deeres. It had to be before 1991 since that's the last year I worked at any Deere dealerships. All the ones I have here are Bosch 33 amp. They have a W (stator tap for tach), D+ stud, B+ stud, and then the brush holder/regulator that sometimes came sealed, or sometimes with two male spade terminals on it. No Deere part #s and I don't recall what tractors I got them from. Probably something like a 2630. Bosch part # 012339 544 545
Bob
02-03-2008 07:21:26
Not much to go one there!
Can you post a photo?
If you just need a simple 12-Volt alternator for a conversion project, try a Delco 10SI.
Third Party Image
Texasmark
02-03-2008 09:19:54
 Re: JD Alternator?? in reply to Bob, 02-03-2008 07:21:26
Is the 10 SI the single lead Delco with the enclosed regulator?
If so, the only hangup to this alt is that you have to reach a certain rpm to get enough voltage generated to make it start regulating, hence develop an output.
So, you could start your tractor and see no amperage on your gauge. Don't be alarmed. Just goose it and watch your ammeter. When she pegs you are good to go. Then you can go back to idle if you want and it will continue to work.
Mark
phil25
02-03-2008 09:42:43
 Re: JD Alternator?? in reply to Texasmark, 02-03-2008 09:19:54
Thanks for the comments, i will try to post a photo later on, using a chev alt was the orginal plan, but when new and free arrives, you have to do what you have to do:) but better to ask just in case.
I was thinking of putting in a oil pressure switch[ as per massey] to control the exciting current, but the russian uses a ground isolation switch[ when you park it] so it will solve the draining of the battery over time problem.
The help is greatly appreciated, and welcome any others who do.
tks
Bob
02-03-2008 09:30:15
The alternator in my photo is a REAL Delco 10SI, still set up the way GM made them.
If you connect it as shown, it will excite and charge at LOW RPM's.
There are aftermarket sources that bastardize these poor alternators for the "electrically challenged", and convert them to "one-wire" alternators using AFTERMARKET PARTS.
That is when the "must rev it up to get it to charge" and "my battery drains when the tractor sits for a week or two" scenarios come into play.
NOTHING at all wrong with the "as original" 10SI's, they are easy to connect (as shown), and likely CHEAPER than the bastardized "one-wire" units.
Texasmark
02-05-2008 07:19:07
 Re: JD Alternator?? in reply to Bob, 02-03-2008 09:30:15
Hey Bob. The last one I bought was from AutoZone and I put it on a MF 35. Hooked up the 1 wire and forgot about it (other than the rev it up part). No problems.
Was I lucky?
Mark
