Your premise is the silliest part of your argument. You claim that - since lead was only added to gas to raise octane - any other benefit from it cannot exist? Seems you better read some verified test data and get away from comic books and/or Oprah Winfrey. Many important inventions and advances in medical science came into use by accident - and not by their original intended purpose. Lead-ethyl as used in gasoline was invented by the same guy that invented Freon - Thomas Midgley. It wasn't invented to be used in gasoline, it was originally intended for use in kerosene motor fuel as an anti-knock agent. He was given the job of coming up with a additive for kerosene that would stop heads from cracking due to severe knocking. He did just that - with the ethyl additive. But, it soon became more popular for gasoline. Your next statement: "Tetra-ethyl lead is the most powerful anti-knock agent ever discovered - around 1000 times more effective than ANY other known substance on the face of the earth." Not true. Overall - it was deemed the most “cost effective” yes. That has proven not to be true in retrospect, given the environmental damage it has done, such as the lead that is now present in soil along highways. Many European countries were using an iron additive, but it tended to foul spark-plugs. Next: "They still don't know why or how it works so efficiently at stopping detonation. Estimates are around one drop per 20 gallon tankfull was all that was ever used for regular. Premium then had 1 and one half drop." Seems "they" is you. Yes it is known exactly how it works. Read the chemical formulas and molecular chains. Average ratio with the original tetra-etyhl additive was 1 part to 1260 parts. That comes to 286 drops of Tetra-ethyl per gallon of gasoline. Next: "Lead was also never deposited in the engine in a metalic form - so how could it possibly lubricate anything? . . . this concept is beyond the inane, next you'll be telling me that my TV is broadcasting a picture of my living room out to the FBI." Well, I can't comment about the FBI and if they think you need to be watched. If so, I hope my tax dollars aren't being wasted on it. Yes it WAS deposited as a lead-oxide that coats the valve seats. In fact, the additive had to be tweaked many times to cut down on the heavy amounts of lead oxides it deposited. As time went on, the emphasis was to get more deposits out the tailpipe instead. Gee wiz, how many valve jobs have you done on older cars and tractors? Sounds like not too many. I don't have elaborate test facilities, but I'm wiling to believe verifed test data from all over the world. It has been proven, over and over, that iron oxides grind up soft valve seats when lead oxides are not there to prevent the wear. By the time unleaded gas became the rule in the USA, there weren't very many gas engines being used in heavy duty use - so it was not a major concern to everyone. Also, many gas engines by that time alreay had hard valve seats - so they were not an issue. I've done hundreds of valve jobs in my life, and seen many soft valve seats get eaten up. I don't have the controlled environment though, to judge what caused what. I was a Deere mechanic for many years and used to curse Deere for NOT using hard seats until the 1980s - because we had a lot of trouble with seat-wear - in gas and diesel engines. The proven fact is - old soft cast-iron seats wear much faster when run on unleaded gas if used hard - like in heavy duty trucks and farm tractors. Test results from all over the world show the same. Now, someone with a tractor kept as a collector's item that is rarely used hard - then it doesn't matter much at all. For someone that does use their gas tractor hard - it would be silly not to spend a little extra money to help prolong the life of the valve-seats. And, that's only if it's still in original condition with soft, cast-in-head seats. Most get updated once a valve job has been done.
